The "Official" Superchips Thread
I've seen plenty of chatter about the Flashpaq 2865, Cortex 2950 and the new VIVID/VIVID Linq Android-based tuners -- so I figured we should dedicate a sole thread to the good and bad of the Superchips' product.
Please use this thread to post raves and rants, your favorite settings, performance achievements, and general Superchips questions!
You can read about the Flashpaq here, the Cortex here, and the VIVID here, and VIVID Linq here.
At this time, Superchips programmers are only compatible with Alpha H3/Ts.
I am running the Flashpaq, which has been mated with a K&N filter and an AirDoc's performance intake. I primarily run the '87 Octane' setting, and I have a noticeable performance increase -- although my mileage has stayed at around 12-14 mpg around town. I don't do much highway travel right now, but when I got the 10+ hours between home and school, I typically hit 16.5 mpg on the interstate.
I have run the '93 Octane' performance setting in the past, and the performance increase was definitely noticeable; however, mileage gains were zilch and the price of premium gasoline have kept me running the 87 Octane setting.
The 'Mileage XS' mode completely neutered my truck, but mileage increases were definitely noticeable -- about a 2 mpg increase.
3rdH3
Blacksburg, VA
To add to the discussion, they DO NOT have anything yet for the 2010 5.3 FlexFuel Alpha 3's or T's. My last contact with them a couple of months ago, they were unaware of any development being discussed for those vehicles. FYI
Hmm, I was fairly sure that someone (Kflips?) was running the Flashpaq on their 2010 with no problems. It is still a 5.3L...and they just recently released a patch for the 2865 so that it works with 2011+ 5.3L's...
Well...hopefully whoever was running it will pipe-up. You can always go with a PCM For Less tune as well, if you haven't already looked into it. They are a site sponsor.
benlaud87
Maryland
You can't change the tire size with the cortex, its advertised that you can, but you cant. I dont think you would be able to with any of the tuners but i may be wrong
ReconH3
Guardian Angel
Raleigh, NC
Like benlaud said, you can't change the tire size, but you can change gear ratios. I'm pretty close to spot on in my speedo just by trying the different ratios.
"Ex Umbris Venimus"
Sent from my iPhone
Timgco
Hugh Hefner
Colorado
I used the Flashpaq on my 08 Alpha and it was great! Improved driveability, shifting for sure. no tire size adjustment. I can confirm no 2010 avail. also. last time I checked with Superchips they were "not going to offer at this time." that was just before the 1st of the year.
H3nightrod
Illinois
I am running a superchips on my H3 alpha. I usually only run perforce mode or tow mode. Both have great amounts if torque and HP but have never recorded mph. I'm sure the mph are low but I enjoy the noticeable Power gain.
The Flashpaq can be had new for around $330, the Cortex slightly more, and the VIVID a bit more.
As far as I know (and trust me folks, I'm no expert -- just voicing my opinion) they all offer the same tunes, just in different packages. The Cortex costs more because it can tune more than one vehicle, and the VIVID is more because it is the latest technology and can be adjusted via your Android smart phone.
benlaud87
Maryland
got mine for 100 bucks because someone bought it thinking it would work with their i5.
I think if you buy a used one you can delete the old vehicle used if it was used for 100 dollars.
Superchips cortex came today, they 87 octane tune = wow, havent tried any of the other ones. what i like is that i can quickly change the tunes from power to towing to gas saver relatively quickly whenever i need to.
Sennin
South Africa
So I just ordered myself the Flashpaq 2865 for my V8, holding thumbs that I won't have any issues with South african sonftware :thumbs:
Wonder how the performance will be with the 95 octane I'm running :huh:
TAPDH3T
Texarkana, Texas
Im running the flashpaq performance setting on my '09 H3T 5.3L Alpha.. Noticeable difference with the 93 Octane at higher speeds and take offs..
Question's????
How do u change the performance setting to 87 octane without using the mileage xs setting???
I have the tire setting changed but would like to use more of the advanced settings.. Anybody have a good setup they are using??
Last, how do u program in ur airdoc and K/N filter???
You shouldn't have any problem with the 95 octance since there is a 91 performance tune, as long as you run 91 or higher your fine
I don't fully understand this question. You can only run one setting (stock, mileage xs, towing, 87, or performance) at a time.
To my knowledge that is not supported. That'd be a great question to ask on the Superchips forum. They are very good about getting back to their customer base.
TAPDH3T
Texarkana, Texas
I dont understand the question either..lol i took the info above as u had the performance setting set at 87 but u are using the 87 setting.. I got it now lol..
2007HummerH2
Maine
Just purchased my Superchips from a forum member. Can't wait to get it! Especially if it does what it did to my Rubicon....it was a night and day difference!
