I looked around on that colorado/canyon website. I'd be interested in any mod that is backed by a dyno sheet. but so far, i dont agree with the berkelium copper mod for a few reasons. Spark power is a function of difference in voltage potential and the dielectric breakdown constant of air. since the dielectric breakdown constant of air typically remains the same in our intake manifolds(relative temps and humidities - not really going to make a huge difference), then we can assume that changing the resistance would have an effect. the power of a spark is actually lower with a lower resistance wire/junction like the beryllium copper mod. the higher resistance the material, then by P=VI and V=IR and P=I^2R, then an INCREASE in resistance would lead to a larger voltage potential across the same gap, same dielectric constant and would produce a hotter spark. dV is the thing you want to drive here, you want as high of a resistance in the spark wires as you can in order to produce a big spark. Dont trust me? Put a voltmeter on a set of Moroso drag racing spark plug wires, and then do the same to a piece of cheap household romex cable. it doesnt look like there is a a good supercharger kit
