I found this on how to DIY........
1. the larger the front is opened up the better.. HOWEVER, be carefull to stay within reason as if you make the TB wall too thin it will crack or break..
2. Once you removed the desired material you can then move to polishing the bore. Avoiding the ventury area.. But you can polish right up to it.. Hand sanding works well moving in a circular motion from about 500-1000-1500-2000 git sand papers. But you can also use a moto tool (be carefull) to remove material and to polish..
3. Never change the ventury bore. It's the area where the butterfly is.. That area is milled specifically for the blade (butterfly) changing its dimensions will cause problems..
4. One thing that is easy to have happen is damaging the ventury bore.. Like said, this will cause troubles..
The other could easily be opening up the rear bore too much..
The rear bore behind the ventury should not exceed the size of your intake manifold inlet diameter..
