JonBishop
- Glendora, CA
im thinking of doing a mod to the hood louver and doing the cut outs... jus trying to get some information if the cut outs really helps with the heat and ventilation thank you :thumbs:
on the hwy the air being sucked out the top is counterproductive.
The H3 exhausts air out the bottom of the engine bay. If you open the top of the engine bay then it takes away from the pressure inside the engine bay that helps push air out the bottom of the engine to be sucked out by the negative pressure under the car. At first glance, it would seem that when you open the hood to get more air out that it has to be more efficient. What actually appears to happen is that as more air comes out the top, the pressure inside the eng bay drops and so does the speed and amount of air coming out the bottom. In effect you still get the same volume of air through the radiator but more air out the top and less out the bottom at hwy speeds. My hope was to have more air coming out the top at slow speeds off road and less heat build up under hood for quicker heat dissipation when parked on the trail or around town when its over 100 degrees outside.I'm curious, how is it being counter productive
