09 H3T Suspension part-out...
Solid Axle Time! (IFS sale)
I'm cutting apart a 2009 H3T Adv. Pak, and got some good parts available. This is a 3.7L - AT truck with 47,000 miles. Everything is good to exc. shape unless noted otherwise.
Parts & prices listed below. I will update this list as items sell...
  • 4.56 geared, cast-iron, locked, AAM-7 SOLD!
  • Rancho lift kit SOLD!
  • GM 8.6 10b 4.56 gears SOLD!
  • GM Front hub 44k miles.....$90
  • Aftermarket front hub 1K miles.....$100
  • GM Half shafts......$90 each
  • GM power steering lines (with optional cooler)....$20
  • GM upper control arms. Good boots & joints. Camber bolts included...SOLD!
  • GM lower control arms. Good boots & joints. Bolts included.....SOLD!
  • GM front brake backing plates. Excellent condition....$30/pair
  • GM front sway bar with mtg. brackets & bushings.....$50
  • THORparts front skid plate.....SOLD!
  • GM steering rack. Tight seam between casting and sheet metal cylinder. Good ends. Junk bushings....$100
  • GM 5-cyl torsion bars, keys, and adjusting bolts....$75/pair
There will be more parts available off this truck as I work my way rearward with the torch. All prices do not include shipping. If you want an item, PM me with your complete address and direct email. I will get you a quote. Payment via PayPal or cash in person. I have many other odds & ends for H3's. Let me know if you are looking for something. -CJ
So how long was it submerged in salt water??
wow glad we don't get that chemical abuse down here in the south.
Haha. True. This is the rustiest 5-year old vehicle I've ever seen. I'm just about done with my second can of PB-Blaster. I've broken four bolts taking the front end apart...pretty good considering the corrosion. Despite the rusty appearance...this stuff is in really good condition. I've had other "prettier" parts that were not in as good mechanical shape as these.
atvspeed4
massachusetts
Wish the shipping would not be a killer for the upper shock mounts you took off the frame :sigh: Still working on coilover conversion and that would help a bunch.
You don't want stock shock mounts for that...way too flemsy. They are not strong enough to support the weight of the vehicle. Get some 1/4" brackets from RuffStuff, Ballistic Fab, or PartsMike. Frame plates are a good idea too.
Woodtick
Ilanoid, UP MI
Your a tease,every thing I wanted is sold. If the 456 gears become available,please call me or pm. Try a can of Kroil,makes rust not such a big deal. Good luck on the build.
Not to hijack but I have a set of rear 4.56s also. Obviously 4speed will sell his first but if you guys need another set I have them
$75 shipped to Michigan? (or $60 and meet me at the Badlands again). I plan to be done with this truck by February...perhaps myself and the owner can convoy the SASH3's up there for some test & tune.
Woodtick
Ilanoid, UP MI
I will take the set for 120. I'm in no hurry. I can get them from you the next time we wheel. I will be working in Gary IN Monday, but that's still a ways from you.
Kflips has done it. I'm about to do It here shortly, I'll let you know how it goes.
Plz do! Its currently on my list of things to do by summer next year! (Unless somehow someone fits a new diff that has better gears upfront, not everyone wants a SA upfront!)
derian06
Red Rockett
Madison, AL
  • GM upper control arms. Good boots & joints. Camber bolts included....$80/pair
  • GM lower control arms. Good boots & joints. Bolts included.....$80/pair
  • THORparts front skid plate.....$50
  • GM steering rack. Tight seem between casting and sheet metal cylinder. Good ends. Junk bushings....$100
How much do you charge for a SAS and where are you located? I'm curious
Just added this to the list of used Hummer parts. Courtesy of Big Red...
This is a THORparts swing-away spare tire gate...designed to fit the THORparts H3T rear bumper. Years ago I made a dozen of these and sold them to numerous customers, all over the US. I haven't made any since, and I don't plan to. Its a tad crusty and needs re-coated but, its structurally sound. It comes with the gate, latch, spare-tire mount, pivot bracket, and large pivot bolt. It will need a new rubber bumper pad, and (4) 7/16" bolts to mount the bracket to the bumper (I had to cut them off). This would work very well if you already have a THORparts H3T rear bumper...or if you wanted a head-start on some other sort of spare tire gate project. $130 plus shipping.
