NEW! Stage Series HitchMount LED Pod Kit | The BEST 5 Minute Mod!
Diode Dynamics
LED Lighting Experts
St. Louis, MO
Diode Dynamics is proud to introduce our Stage Series HitchMount LED Pod Kit!
Features:
  • Allows you to mount an SSC1 or C1R LED pod in any 2-inch trailer hitch receiver.
  • Adds a powerful reverse light, 4th brake light, and additional running light.
  • Simple 5-minute installation, with no need for custom wiring or routing wires.
  • Optional SafetyStrobe brake light strobing.
  • Designed and assembled in USA.
Add significantly more light output when backing up at night with our Stage Series HitchMount Reverse Light Kit! This kit allows you to mount one SSC1 or C1R LED pod in your 2-inch trailer hitch receiver, adding a high-power reverse light, additional running light, and an optional 4th brake light with the C1R option. With the included wiring harness, this kit connects to your vehicle's factory trailer hitch wiring for simple, everyday operation.
Brighter Backup. Factory reverse bulbs just don't provide enough light output to back up at night confidently. By pairing our patented TIR optics with high-powered LEDs, the SSC1 and C1R included in this kit provide an additional reverse light that's several times brighter than stock bulbs alone. Plus, they automatically come on when the vehicle is put in reverse!
Additional Running Light. The Stage Series LED pods included with this kit feature a distinctive red backlight that can be used as an additional running light while driving! The backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.
SafetyStrobe 4th Brake Light. The C1R option features a high-power red function to serve as a powerful 4th brake light, along with the low-power running light. The high-power red functionality activates anytime you apply your brakes, adding a 4th brake light to your vehicle.
The C1R also features optional brake light strobing. By default, the C1R will flash three times anytime the brake lights are applied, for greater visibility. The SafetyStrobe feature can be easily disabled if desired.
Everyday Operation. This kit is completely plug-and-play with all 7-pin trailer connectors. The included harness plugs right into your factory trailer hitch wiring for easy installation and operation. The kit operates as an additional red running light with your tail lights, and then automatically switches to a high-power backup light when your vehicle is in reverse. The high-power 4th brake light feature included with the C1R will activate anytime you apply your brakes. If you would like to have override functionality to manually turn on the reverse light anytime, you will need to purchase the universal backup harness.
If your trailer connector is not 7-pin, this kit will still work for you but will require slight modification to the harness.
Simple Installation. The patent-pending snap-fit design allows you to install this mount in minutes, without any drilling or need for a hitch pin. Simply insert the HitchMount into your trailer hitch receiver and the snap-fit side mounts will snap into place. Installation couldn't be easier and takes less than five minutes!
This kit is ideal for anyone who uses their trailer hitch often since removal can be done in minutes as well! Simply unplug the harness, press the snap-fit pins and remove the mount. When you're not using your hitch for towing, you can quickly reinstall the HitchMount and plug it back in.
Focused. Traditional optics like reflectors or simple lenses lose light internally and to glare, so not all of the light shines on target. Instead, the custom-engineered TIR optic in our Stage Series pods collects all of the light from the LED, and directs it only where you need it, drastically reducing glare and improving total efficiency. Click here to learn more: Total Internal Reflection (TIR) Optics | Stage Series Video.
From there, while other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the Stage Series LED pods serves as both the optic and main lens for greater efficiency and light output (patent pending). Thanks to this innovative feature, when coupled with high-intensity LED chips, the total intensity of our pods is much greater than other LED pods using basic optics or reflectors with a standard outer lens.
Functional Output. All Stage Series beam patterns were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern.
  • Flood pattern was designed to provide uniform, even illumination with a full 50x50 degree spread of light on the SSC1 LED pod. Unlike generic "flood" lights that are simply a heavily diffused spotlight, our flood pattern uses pillow optics on the outer lens surface, to provide a true optically designed spread, for even illumination throughout.​
Security. If you would like to use a locking trailer pin to install this kit instead of the snap-fit pins, you can do so with a quick modification. Check out the YouTube video above!
Proven Reliability: Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
If you have any questions, please don't hesitate to post, PM, or email contact@diodedynamics.com.
PM us for the free-shipping code (U.S. forum members only)
John C.
Diode Dynamics
Does the DD wiring harness act as a pass-through for the 7 pin connector? For example, if I want to tow a trailer I just remove the LED Pod, leave the DD wiring harness intact, and plug in my trailer wiring as normal?
Diode Dynamics
St. Louis, MO
Correct. You can see more at the 2:12 mark on our YouTube video.
Diode Dynamics
St. Louis, MO
Our Black Friday Sale is LIVE! 🚨 Visit the website for our BIGGEST savings ever!​
20% OFF Sitewide
30% OFF Stage Series Single-Row Lightbars
15% OFF Elite Series Headlights
➡ Free US Shipping on any order with a HitchMount LED Pod, or orders over $300.
No coupon code is required.
Click HERE to shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday, 11/29/2022. Cannot be combined with other coupon codes.​
Diode Dynamics
St. Louis, MO
Our BIGGEST and LAST sale of the year ends TODAY 11/29 at 11:59 pm CST!
20% OFF Sitewide
➡ Plus, orders over $300 receive free US shipping!
Excluded Products:
Hitch Mount LED Pods (Includes free US shipping)
CLICK HERE TO SHOP!
John C.
Diode Dynamics
Sale ends at 11:59 p.m. CST on Tuesday, 11/29/2022. Cannot be combined with other coupon codes.
Diode Dynamics
St. Louis, MO
⌛THE CLOCK IS TICKING... ⌛
NOW
is your chance to SAVE up to 15% sitewide on your favorite Diode Dynamics LED lighting products.
Up to 15% OFF LED Lighting Upgrades
➡ 15% OFF Stage Series Rock Lights & HitchMount LED Pods
10% OFF Elite Series JL/JT Headlights
➡ Free US Shipping on any order over $300!
CLICK HERE TO SHOP NOW
Did you know?
You can find all of the products we offer for your vehicle using our vehicle finder tool! Simply enter the year, make, and model.
SALE EXPIRES 11:59 P.M. MONDAY, MARCH 13TH, 2023.
Discounts cannot be combined with other offers or any previous orders. Excludes items with pre-order status.
Diode Dynamics
St. Louis, MO
🚨 Our Memorial Day Sale is LIVE!!! 🚨
➡ Up to 15% OFF Sitewide
10% OFF JL/JT Elite Series Headlights
➡ Free US Shipping on any orders over $300!
Excluded: F150 Elite Series Headlights, and F150 Elite Series Fog Lights
John C.
Diode Dynamics
Hours: Monday-Friday 10 a.m. - 5 p.m.
Email: contact@diodedynamics.com
Phone: 314-205-3033
Sale ends 11:59 p.m. CST on Friday, 6/2/2023. Cannot be combined with other coupon codes.
Diode Dynamics
St. Louis, MO
John C.
Diode Dynamics
Phone: 314-205-3033
Diode Dynamics
St. Louis, MO
⏳ WARNING! TOMORROW IS THE LAST DAY TO SAVE! ⏳
Up to 15% OFF All Lighting Upgrades
FREE US Shipping on any order over $300!
Click HERE to shop lighting upgrades for your ride!
🚨 Sale ends 11:59 p.m. CST on Friday, 06/02/2023. Cannot be combined with other coupon code 🚨
John C.
Diode Dynamics
Phone: 314-205-3033
Diode Dynamics
St. Louis, MO
Ignite your lighting game this July 4th!
20% OFF Single Row Stage Series Light Bars
15% OFF Sitewide
10% JL/JT Elite Series Headlights
Plus, score FREE shipping and a FREE Diode Flag Tee with any purchase over $300!
NO COUPON CODE REQUIRED
https://www.diodedynamics.com/ ⬅️
Expires at 11:59 p.m., Friday, July, 7th, 2023.
Diode Dynamics
St. Louis, MO
It's our LAST SALE of the summer!
Save BIG on premium US-assembled lighting sitewide!
The time to upgrade is NOW!
20% OFF Single Row Stage Series Lightbars
10% OFF Sitewide
FREE US Shipping on orders over $300!
The sale ends Friday, 9/8.
*Exclusions apply. While supplies last.*
CLICK HERE TO SHOP YOUR RIDE AND SAVE!
Did you know?
You can find all of the products we offer for your vehicle using our vehicle finder tool on our website! Simply enter the year, make, and model and all options will appear.
Diode Dynamics
St. Louis, MO
10% OFF Sitewide
Did you know?
Diode Dynamics
St. Louis, MO
This is our BIGGEST & LAST sale of the year here at Diode Dynamics but only while supplies last! ⏳
20% OFF Sitewide
15% OFF Elite Series JL/JT Headlights
Plus - Receive Free US Shipping with orders over $300!
⏰ While supplies last... Sale ends on 12/1/23 at 11:59pm CST ⏰
Questions/Concerns:
Hours: Monday-Friday 10 a.m. - 5 p.m. CDT
Phone: 314-205-3033
Joebob
Washington
I know this is more or less a dead thread, but I figured I'd post just in case someone else has this issue and DD can help work out the problem.
I've used the plug-and-play harness and installed my Hitch light. However, with the running lights on, the hitch light is white; in reverse, it is white; with hazards on, the hitch light flashes red to match the driver's side light. The odd thing is that the passenger tail light turns off. If my hazards are white flashing, I press the unlock or lock on my key fob, and the passenger light reports as normal. my wiring and connectors look fine at first glance.
Is there something I need to change in the pinout of the hitch light? Do I need to tap another wire for proper operation? I checked the site for directions, and nothing seemed to detail solutions, and the Q&A was not helpful.
Thanks in advance.
Diode Dynamics
St. Louis, MO
That's unfortunate to hear and apologize for the inconvenience!
We have not heard of this report before here on the social media team.
Please go ahead and give us a call at 314-205-3033, Monday-Friday 10 a.m.- 5 p.m. CST, or shoot us an email at contact@diodedynamics.com, and our in-house US service team would be happy to help you with that.
Hours: Monday-Friday 10 a.m. - 5 p.m. CST
Phone: 314-205-3033
