adventr
- United States
So my '09 had the factory headlamps as the daytime running lights. I recently did a projector retrofit, and pulled the DRL fuse.
I would like to use my fog lamps (or something else even) as the DRL, so is it logical to think that:
- Factory DRL power was sent through DRL fuse
- Pulling fuse broke the link between BCM and DRL lights
- Tap into one side of the DRL fuse holder (the side coming from BCM)
- Use that wire as a trigger for a new relay
- Run relay output to whatever lights I want to use as DRL
Has anyone done this? Sounds like it would work, at least in theory...
