Pre-Moab To do list?
I think we have your checklist ready, sir:
  • Verify wrong size tires are on the T
  • Discuss wrong size tires are on the T
  • Procrastinate about wrong size tires on the T
  • Discuss procrastinating about wrong size tires on the T
  • Drink a beer and tell Cotilo that the wrong size tires are on the T
  • Discuss on the forum that you discussed with Cotilo that the wrong size tires are on the T
  • Schedule Alex to come down and help correct the wrong size tires on the T
  • Discuss Alex coming down to help correct the wrong size tires on the T
  • Verify that you're out of Scotch, which is why Alex bailed on coming down to correct the wrong size tires on the T
  • Place a Craigslist ad for day laborers to come replace the wrong size tires on the T
  • Buy Moose Drool and drive to Moab
Thank you. You are correct on all items listed on my checklist. So, when can you get down to Tucson to put the right size tires on my T? :D
You forgot buying the people from Craigslist dinner at McDonald's.
Could buy Brian's tires at a steal and have a tire shop install them.
frumaker
killeen, tx
I gotta build a rear bumper since I mangled the other one. Anyone wanna help? I need motivation and help with a design
FRU
LagunaH1
Idaho
Let's see:
Clean truck
Load tools and parts into truck
Re-install radios in truck
Re-Install antennas
Fill up the tanks
Cyouincourt007
Pavement Prince
Miami,Fl
Bump...any checklist for this year including making sure big still has wrong size tires on the T. :wink:
The list does provide useful info for the rest of us to watch and learn.
For me, Not too much. I have a new header and motor mounts I am putting in now, tires are new, suspension is fresh and new. I think after the KOH trip will determine what I need.
New transfer case. Maybe new battery. Maybe new ignition housing for the Passlock issues that have been dormant recently. Hope the throttle position sensor issues don't come back. See what items I might be able to remove from the trail kit and from the truck in general to offset the weight of some of the other new things. Maybe pull out the scissor jack since I carry a bottle jack (and hi-lift) on trails?
Keep checking oil as I was a quart and a half low last week after 3500 miles since the last oil change (WTF?). New driver's side upper control arm and alignment. Weld on new nut to crossmember since the last welded on nut is stripped out.
LagunaH1
Idaho
Regular service
alignment
Check tie / radius rod ends
Check ball joints
Rear AC
CTIS pressure gauge back light
Mechanical resonance / vibrating when stopped while cold in D
Pass window up / down switch in center console
Leak at T-case cooling lines
Leak at front of engine block
Regular service
alignment
Check ball joints
Rear AC
Isn't all that just known as the standard "H1 1000 mile service"? :)
Panzer07
Ontario, CA
Pretty much, yes :hans:
Even then I still want one...alright I don't remember military Hmmwv needing that much maintaining after 1,000 miles lol
Torres
"He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you."
-Friedrich Nietzsche
Timgco
Hugh Hefner
Colorado
I don't have much in maint. to do. I do need to call Dave and see if he can bring an "extra" HUMMER though. :wink:
LOL, spoke to ****in soon......DAMN IT!!!
This is my next big trip hopefully it goes better then this past weekend.
