- Indianapolis, IN
For all of you electrical gurus.....So only 1 out of the 6 off-road lights i have is working. I check all bulbs, they are fine. They are wired up in groups of two. I am fairly certain that in the grouping of the one that does work, that the connection is just corroded and just needs to be cleaned up. All fuses in this harness are fine.
Problem 1.) For the harness that connects the two lights on the BA bumper, both of the lights work, only when hooked up to one side of the harness, when i plug them into the other half, the fuse blows. I am thinking that there is a short in the wiring somewhere for that harness? Thoughts?
Problem 2. ) the two lights on the harness connected on the passenger side of the H3, using a voltage tester, i determined that there is no electricity running up to the lights at all. I am not sure where to start looking in this harness for the culprit, All fuses are fine. Thoughts?
I should add that when i had these wired, there is only one heavy duty wire with power that is coming through the firewall, so as to limit the amount of punctures made and chances of water getting through.
I realize that this isnt hummer specific wiring but i figured someone could give me a direction to go, instead of my messing with it for hours on end with no success. Thanks!!
