WTB Your broken transfer case parts
I believe there are four cases as Alphas and I5s have cases with physically different dimensions. And of course each one can be base ratio or 4:1
reaper
Denver, Colorado
There's only the 4493 and 4494. Earlier cases had the plastic shift fork, newer ones have an aluminum shift fork. 4493 (aka NR4) is the base package, 4494 (aka NR6) is the adventure tcase. And all components EXCEPT for the hi/low carrier and the hub that goes into it are shared.
FYI this is the internal parts diagram: http://parts.nalleygmc.com/showAsse..._driveline=0&ukey_trimlevel=15498&modelYear=0
But much cheaper through gmpartshouse.com or hummerpartsonline.com.
reaper
Denver, Colorado
ok, I see it:
Bigunit says: "Part # for the 3.7L 4:1 TC is #24247592. The part # for the V8 TC is different and the 2 cases are NOT the same, so make sure you get the right case based on the engine size."
Not sure about that, I think there's only these 2 models with shared components, and it's the adapter that is different. Regardless, I could use some parts to do a little rebuilding. :)
reaper
Denver, Colorado
Ok... after taking Backcountryislife's 4493 apart, here's what's different: the main shaft, the ring gear, the high/lo assembly, the hi/low hub. Those parts alone to make the 4493 into a 4494 will run at LEAST $1240.91 (priced from hummerpartsonline.com). So.. probably not worth it...
BTW, we have some extra parts laying around here in Denver if you have something broken.
reaper
Denver, Colorado
Hey Summit!!!
Well, SOMEWHERE along the line there was an assembly issue with my tcase. Not sure when... but currently, nothing is broken, gears all appear fine, the mechanical shifting action is correct (confirmed with backcountryislife's tcase), but it just doesn't shift all the way into 4 low. The shift cam has some flexibility, so if you stretch it out it will work a while until it compresses, and then I'll be stuck on a trail and it won't go into 4low. If I were to just add a spacer into the shift cam (like 2 washers) it would lift the shift fork enough to engage 4 low. But I did order some new parts (just got the shipping notice) and am hoping that there was something defective about the 4low hub gear, it does appear to be too long, we're wondering if an incorrect hub was installed which throws it all off. We'll know more in a few days when the parts come!
reaper
Denver, Colorado
Actually I was wondering if there was some great off-road carnage story I had missed! :)
Yeah.... I got stuck on the back side of Bill Moore Lake trail with no 4 wheel low... and with my hamster engine, it wasn't gonna make it up and over without a tow. Going down after I got towed up really sucked too. Luckily, I found a tow from a jeep on the trail, and backcountryislife was close and met me back on the way down.
It happened like this.... before it happened, I would hear some pretty loud POPs. I thought nothing of it but my wife was like "what's that? Something's not right...". She was right. It was the 4-low hub popping out of gear. Eventually, it popped out and couldn't get back in. Had the whole family with me... it was a great trip. :)
SummitUp
High On Hummers!
High In The Colorado Rockies
Oh man, there's nothing worse than getting towed by a Jeep!:shame: I can just see his "Hummer Recovery Vehicle" bumper sticker! :gaah:
It's always risky wheeling by yourself, but we do it all the time. So far we haven't regretted it yet (knock on wood)!
