K0PIR
- Pierre, SD
I have a transmission cooling line seeping a little bit where the metal joins the hose (near the radiator). I bought replacement lines on Amazon ($17 & $20), but reading through the service manual it says to lower the transmission to install the lines. Is that right? Has anyone replaced the lines without lowering the transmission? It's been raining here for days and I haven't gotten out to take a closer look.
If the transmission has to be lowered I guess I'll just replace the bad section with some hose. I'm thinking I could cut the bad section out, double flare the ends and install a hose with a couple of hose clamps. Is that the way to go?
