I've been doing some reading and haven't really found a consensus on this. I've had my 2006 H3 for a few weeks now. The steering feels heavy to me if you turn the wheel much farther than you would if you were making a normal turn. It is especially noticeable making tight turns like a drive-through. Steer it sharp enough and it requires more throttle to continue moving. I've steered all the way to lock and got out to check and the tires aren't hitting anything. It's got a torsion bar crank and some XD Rockstars with 285/65R18 Nitto Trail Grapplers. I bought it that way. I know it's full-time 4wd, so I didn't initially think much about the steering feeling heavy, plus the weight and width of this wheel and tire package can't be helping; but it's starting to worry me.
After reading some about the 2006 model year and the plastic shift fork I started wondering if it may actually be stuck in 4-high lock although the light on the dash shows 4-high. With the transmission in neutral I can switch among all three 4wd settings. It definitely goes into 4-low as evidenced by a short drive test. No question on that one. I can't really hear anything going between 4-high and 4-high lock though. I tried backing up 100 feet or so for good measure (in 4-high) with no noticeable change. I read in a post somewhere about a guy saying that he always shifted his transfer case into neutral then back to 4-high when it got stuck in 4-high lock. I tried that. The TC for sure went into neutral, dash indicator N as well as no movement of the vehicle in drive or reverse. I pressed the 4-high button and after hearing the clunk it was back to normal. I do think I feel a difference in the steering at this point but it may be placebo. The main part of this post is to ask if the TC would go into 4-low or neutral if the fork was broken? Is there any other way to determine if it's actually in 4-high lock?
At a cruising speed from 70-75 MPH I'm running about 2500 RPM. Is this a normal range? I'm calculating MPG based on the trip odometer reading divided by gallons of fuel at fill up. It's averaging around 14.5. Does that seem about right based on the wheel and tire package?
