H32NV
- Golden, CO
What would be involved in a swap from a 3.7 to a 5.3L other than motor, maybe some adapter motor mounts, ECU, and exhaust?
Most likely a 5.3L cal won't load on a PCM; but I could be wrong; honestly never tried it. (The mention of the H3T swap was a lot easier since the T's came out after the firewall re-design and the swap from using a single controller to two separate controllers (PCM to ECM and TCM).
Depends on the year. In the 08+ the I5's and V8's use the same PCM and TCM, so you could certainly reuse what you've got. We can handle stuff like that here as well, we have all of the GM software for reflashing new VIN/operating system, and then of course tuning.
Yeah the 4BT is without doubt the "go to" motor for a vehicle the size of the H3. The only downside is that the 4BT is a true "mans" diesel. They are loud, rattly, shakey, and all of those things that make people hate (or love) diesels...they're downright obnoxious! 4.10s might even be too low for it (unless you run 37"s). He was shooting for 23mpg.
Whatever the case...I got a buddy that has a 4BT, an NV-4500, and twin-stick gear-driven NP205 sitting in his TJ frame. I think he's burned-out on the project and I keep waiting for him to bail and sell me the drivetrain on the cheap. He's also got a D60 front axle and a trussed, disc-braked, 14-bolt FF rear to go with it....3.70-geared. I'm waiting for the bank to come after his house...then we'll talk! -HA.
