Suggestions
Bananatank
Hammond,la
Can i get some advice here
1) I'm trying to get some new subs my old one is rattling or blown but its time to go so I'm about to replace it but idk what to go with... Anyone have any ideas on this? I'm trying to not use a lot of my Cargo area if thats possible. If you have aftermarkets subs or a sub can you post a pic that would help alot[emoji106]
2) idk if anyone knows anything abt this but I'm also trying to replace my little spotlights bulbs i have on my brushguard bc they are a different color than my hids. If anyone has a suggestion for a bulb i can replace the ones that are in the right now with, so that they are close to or match my hids that would be really helpful. (Here are the lights i have right now btw http://m.ebay.com/itm/121362938537 )
3) anymore suggestions for further improving the look of my hummer would be nice some of y'all's favorite mods that yall suggest[emoji108]
Thanks guys
New Jersey
1.Pyle Drivers and Crunch are a few good afterbrands. I will take pics of what I have (my base sound is a custom built kicker box with 2 base speakers with a separate Amp just for those speakers)2.im sure they make LED bulbs that will fit and come closer to match your HIDs (I believe they need to be 6000's) or another option is to custom make a set of smaller sized HIDs fit into where you have those bulbs, yes you would have to mount the ballast too.3.as far as mods, the skies the limit, or should I say your budget is the limit. My suggestion is make the vehicle both mechanically stronger (better intake(DOC) exhaust, tie rods, upper control arms, plugs, alternator, dry cell battery,etc) and the body stronger in case of an impact (heavy duty pushbumper, preferably one that goes over the hood as well)
mudbug
trail blazer
Brighton,Co
I'm running a aftermarket sub box made for a single cab truck that fits 10" kicker solo baric and it doesn't take up to much cargo space. I believe the box is designed for a 97 and up f150.
If you have a factory sub you could remove the speaker from the box and install a better sub with a different amp and use your factory wires to power your amp. That's if it is possible to do with a h3, I know it can be done in a Ram.
For your spot lights I would pickup some LEDs (but it looks like they don't put out that much light) or convert them to hids for more light out put. A guy I wheel with just talked about converting his auxiliary lights to hids and I found threads that people have done this to KC Lights.
Bananatank
Hammond,la
Okay thanks you two so far[emoji106] if i could see a pic of your sub mud bug that would be a big help[emoji106] i would say yours as well renegade but i hv an h3 lol okay abt the second problem i need something with decent light output too trying to get it as close as i can to my hids as possible i found out all the info on the bulb if that helps any of you track down a bulb for me bc i really don't know wtf I'm looking for here the bulb in it right now is a h1 high beam fog light or atleast thats what the manufacturer told me. If someone can help me track down a bulb which is close to the same color as my hids and still shines far and fits in my housing right now you would be a huge help[emoji108] bc I'm not finding much
mudbug
trail blazer
Brighton,Co
Pm replied
I'm no light expert but if you would like to get close to hid I would grab some tinted high beam bulbs that matches your hid color at the highest Kelvin rating, but make sure the wiring and the light housing can handle the extra heat and wattage.
I just got on eBay and looked at some blue,purple, and a yellow tinted bulbs.
New Jersey
This thread link I just posted is by Diode-Dynamics, which is one of out forum members and I believed a sponsored vendor we support.
