Spark plugs for a SC 6.0?
BlownH2
Everywhere
Hello all, I just purchased a 62xxx mile 2003 h2 with a side mount whipple supercharger, I was curious to see what everyone else with a supercharged H2 is running for plugs and the gap size. I've looked high and low and can't find a solid answer. Thank you in advance
fastedmoe
Vancouver WA
Her is something for you I also have a 03 H2 supercharged.
http://www.superchargersonline.com/index.php?main_page=page&id=27
jakesz28
Cabool MO
NGK plugs are very common in any performance application. But if anyone tells you a TR6 or a TR7 do not listen. Those are extended tip plugs and run several hundred degrees warmer. A NGK BR6ef or BR7ef would be suitable depending on use and power gained.
TonkaTank93
VA, USA
How are yall's deuces holding up after being charged? I've toyed with the idea but I was wondering if I should beef up the rest of the drivetrain (Transmission, drive shafts, axles, etc) and steering components first.
