!!!!COMING SOON!!!!
RD Spec transmission features:
Each trans is dyno tested to ensure quality of build!
High performance intermediate billet servo
High performance overdrive billet servo with 50% more holding power than the stock overdrive servo.
Oversize pressure valve
Alto Carbonite carbon fiber PowerBand with thicker hardened anchors that holds in second and overdrive
"The Beast" reaction shell
Super Street Raptor torque converter w/ 1800 stall
8 Red Eagle clutches
Full thickness Kolene steels in the 3-4 clutch
5 Pinion Planet Gear
Transgo performance valve body plate
Element Borg Warner Forward Sprag
Derale performance transmission pan cooler w/ drain plug!
Teaser pictures-
Pan with ported tubes to help keep the fluid cool.
Only adds 1" to bottom of the OEM pan leaving plenty of room for your UCP to clear.
Dual pass trans cooler with Efan that pushes 600CFM. Keeps transmission cool when stopped on the trail.
Teaser pictures-
