offroad - things to remember
kflips
Virginia
A couple of years ago when I was getting up to speed on offroading I had taken notes from a lot of various threads on things of note/ to remember. I recently found it & figured I would post it up.
It's like a new Wiki page - it will be corrected and disputed but I figured I would post it up. If this stuff is already on another thread it can be moved.
Crawling 4lo 1 locked
Hill climbs 4lo 2 locked
Long hill climbs with loose dirt 4lo 3 lock or 4 hi 2 lock
4 hi lock requires hacking into harness, you can make it all plug n play/ switch back
Air down increases traction - traction = broken parts watch the skinny pedal
Try to keep vehicle raked forward - the rake is important simply because whatever you can push the front over, the rear being higher should have no problem clearing it
RAD1 recommended for H3T 30% lateral = 20 degrees
60% fwd/back
Key offroad Replacement parts
- serpentine belt` - steering gear rack
- inner tie rod - half shafts (2)
- outer tie rod - rear axle shaft
- rack bracket & bushings - rack & pinion
Wrecker - Rausch Creek Jerry 717-691-2000:shame:
panty hose = temp. accessory belt, compression bandage, pre-filter in dusty areas
when off roading - place largest obstacle you must conquer directly in front of your tire
When deep fording water (that you know the depth of), enter slowly, gain a few miles an hour, back off of the throttle and then get right back to the same speed. Will create a bow wave in front of you
Use a grease pencil and mark where your wheel weights are on your rims.
Always check what's on the other side of a hill before cresting the top
Always lay a jacket, large towel, floor mate, etc. over the top of a winch cable when winching
Always bring extra drinking water and first aid kit
Keep your thumbs and fingers outside of the steering wheel
Bring a bar of soap - rubbing a bar of soap on a leaking gas tank will seal the leak
Bailing wire, duct tape, pantyhose, and a big hammer can fix just about anything
Epoxy putty can be used to seal gashed oil pans, a hole in a gas tank or radiator, repair a stripped bolt, and more
Spare fluids: engine oil, brake fluid, coolent, transmission fluid, water, power steering fluid, gear oil
Have a 5 gallon bucket for a tool carrier, a fluid catcher, a water carrier, etc.
Great stuff, definitely taking some advice from the list. I do have something to add, i learned this from troy (spongebobnopants).
A pump bottle with a squirter, like the ones you use for spraying weeds, filled with water is a must. Helps with the removal of mud when your wrenching on parts, and washes your hands after your done!
JGBB04
Tampa Bay
Good post, always nice to share tips & tricks of the trade.
Got a couple questions on some of this
Are you talking about using 4lo/hi lock with 1/2 gear or using lockers
And what hacking into harness are you doing
TAPDH3T
Texarkana, Texas
I have the same question as JGBB!! And 3lock?? My adventure package only has two lockers.. Front and rear unless im confused on the meaning lol
Scarsman
Monroe, WA
I'm thinking he is meaning the following, assuming an automatic transmission with 1, 2, and 3 being the shifter positions:
Crawling 4lo 1 locked = Transfer case in low range, transmission in 1st gear, rear diff locked
Hill climbs 4lo 2 locked = Transfer case in low range, transmission in 2nd gear, rear diff locked
Long hill climbs with loose dirt 4lo 3 lock or 4 hi 2 lock = Transfer case in low range, transmission in 3rd gear, rear diff locked, or transfer case in high range, transmission in 2nd gear, rear diff locked
4 hi lock requires hacking into harness, you can make it all plug n play/ switch back = being able to lock rear diff in high range.
JGBB04
Tampa Bay
That's how I was reading it but wasn't sure. I was curious as I don't use my lokckers right away unless it's an obstacle I've done before & know I'll need them or someone tells me I'll need them. I try stuff w/ out them once then try just the rear, if that doesn't work I'll add the front
kflips
Virginia
Yeah - I meant what he said - of course it's one set of basic rules -- My big unknown for these rigs (mine is somewhat heavy) is when to use the front lockers.
