Need help with H3 Rear Turn Signal Light
ADOR
Las Vegas, NV
My wife's H3's Right Rear Turn signal light is busted. I replaced the bulb with a new one. The old one looked OK. But I have decided to replace it anyway. The grey bulb holder showed some "light" burn marks. When I turned the ignition, the bulb lights up. But when I turn the Right Hand signal light, nothing is happening. Any thoughts or ideas on what is wrong?
Thanks for the input.
Try another bulb too as maybe that one was bad - it is two different filaments. Other than that, abntroop is right on target. Those sockets are known to fail or you could have a frayed wire.
Might be the socket which is only serviced as part of the harness. Harness is fairly cheap. Pm me on it Orlando
ADOR
Las Vegas, NV
Thanks for the suggestions fellows. I will check the fuse box when my wife gets home tonight.
Zach, I sent you a PM. I drove my H2 to your shop this moning for oil change. I didn't know the shop closed down for business. Where do I take my H2 now?
