rsm688
- mississippi
Okay guys well after a vehicle that would not move at all (felt like it was in neutral) and had no park. I pulled the t-case, swapped the broken plastic shift fork out, put it all back together. Now the vehicle will not move at all in normal mode, I do have park now. When I am in 4Hi/4Lo it drives around fine. I noticed when I was in neutral and shifted it back to normal that the front driveshaft was spinning like crazy just in Neutral. The rear shaft was not moving at all. Also, I noticed when I had the shafts off I could turn the front diff flange by hand. I'm guessing something is toast in my front end, I'm hoping it's not the front differential.....I want to bash my head into a wall right now
Both my axle shafts appear fine from the outside, I tried to turn them both by hand and they did not budge.
Any ideas?
Oh yeah it's an 06 H3 Adventure
Thanks,
Spencer
Any ideas?
Thanks,
Spencer
