My radio wont turn off....
So i only noticed this after the badlands run this weekend, my stereo won't turn off when i turn off the car and remove the key and open the door. The on off switch works fine but the auto on and off doesn't work thoughts?
Well everything seems to turn off after a while but not when they should, checking the fuse as i type this
Im gunna bump this thread because the problem has returned. The dome lights work as they should, but the stereo still keeps goin. I have pulled the fuse and blown out the fuse box but that dpesnt seem to be helping any. Suggestions? The stereo will turn off awhile later, just not when its supposed to.
Another new development, the radio does the auto turn off when the passenger door opens...weird !!
M22KLARS
Unsafe At Any Speed
Minnesota
Yup! I've had it happen to my rear hatch door probably 5 times. Go around and check every door. See if you can pin point the problem to one door.
