My truck has had a very minor leak coming from the right front under the air filter housing, dripping down onto the A/C lines. At first when I purchased the truck, I thought it was Freon coming from a cracked A/C hose. I have figured it out that it is actually ATF. I pulled the air filter and noticed a little bit of fluid at the bottom of the housing. Everything on the internet tells me this is a sure fire way to tell me my truck has a vampire. With that said, my transmission fluid is still perfect on the dip stick at operating temp and has not dropped at all. I pulled the fill plug on my transfer case and I did not have any excess ATF come out, it was right where it should be at the bottom of the hole. I also pulled the fill plugs on two hubs to see if they had any red juice but they were pure 80/90 and good to go.
I guess I should add that when I first got the truck, I went through all checked all the fluids and added a little ATF thinking it was low. I was stupid and forgot to get everything up to operating temp and may have overfilled it a little bit. (Nothing crazy) Maybe this has something to do with it?
I know Mikkel said he had replaced the transfer case at some point in the past so I am not sure if this was just uncleaned residual from a previous problem or not. Is there any other reason I would have ATF in the housing? I've put around 2,000 miles on the truck since I've had it without any issues, but stopped driving it this week until I can go through everything and find out what the deal is. If it is a vampire, is it as easy as opening up the transfer and just replacing the cooling hose?
Thanks in advance.
Thanks in advance.
