ISO Fuel pump
jurdddd
Eastern Kentucky
My fuel gauge went haywire the other day and my 07 H3 suddenly stated making fuel. Im pretty sure I've narrowed it down to my fuel level sending unit on my fuel pump. I don't want to spend $300 on a new pump when mine isn't technically bad, so if anyone has anything I'd sure appriceate it. Also, I've seen that you can buy the sending unit separate for like $50 just wondering if anyone has had any luck going that route. I've never disassembled one before and don't want to take the gamble without having some knowledge.
If it's just the fuel gauge sender and the pump itself is fine, then you can just replace the sender. Though since you have to go to the trouble of dropping the tank anyway, you might want to just replace the whole thing. But the sender itself basically clips onto the pump assembly, nothing to it.
Personally I'd just replace the whole thing since dropping the tank isn't something I'd want to have to do twice. Then you can keep the old pump as a trail spare in case you're in the middle of nowhere and the fuel pump goes out on you. Better to have it and not need it than to need it and not have it.
It also might just be a wiring issue though, you might want to troubleshoot it a little more first and save yourself the trouble of dropping the tank.
jurdddd
Eastern Kentucky
It started out working fine in the morning, I had 1/4 tank of fuel when I went to work which sounded about right by how far I had driven. I came out after work and had 3/4, shut it off, started it back and it went to full. Driving home and it went from full to empty and my low fuel light came on. Then about 10 miles later it went back to full. Any ideas of where to troubleshoot before dropping the tank?
I'd start by checking the wiring right at the fuel pump, see if it looks like anything damaged it (mice maybe?). Then if you don't see anything, you could test the sender by hooking an analog volt/ohm meter set to measure ohms to the connections for the sender (looking at the schematic, I'm pretty sure it's the two inner connectors, it's a four terminal plug, the inner should be the sender, purple and black, and the outer two wires would be the fuel pump motor, grey and black but probably larger gauge than the sender wires).
With the meter hooked up, try sloshing around the fuel in the tank by rocking the vehicle and see what kind of changes it shows on the ohm meter. You'll want an analog one with the needle since it's a lot easier to watch changes with something like that than with a digital meter. If you see it swinging all over the place and not settling back to the same point every time, then I'd definitely say the sender is bad.
If that doesn't seem to work then you can check the wiring by shorting together the sender wires on the other plug with some wire and then going to the engine bay, unplugging the connector to the engine computer, and testing pin 12 (purple from sender) and pin 29 (black low voltage reference). It should be pretty close to zero ohms. if it's not or if it goes completely to zero, especially when wiggling the harness then there is something damaged in the wiring. But it's more likely the sender itself is bad.
It'll be easier to test all this with another person helping you, but it can be done by yourself.
