HELP>>>A/C only blows on coldest setting
Mizery13
Orlando
Hey Mike,
My 08 H3 has a great working A/C. One issue: I have to keep the dial set on the lowest setting ie; all the way to the left in order to have cold air. Sometimes, it is too cold. If I move the dial even one click toward a warmer setting, the A/C seems to go into heat mode. This makes me have to keep it at the coldest setting or not have cold air. Any idea if there is a sensor or anything that I can check or replace? I am thankful for the cold air as I live in FL but some mornings it's just too cold. Any advice would be greatly appreciated in advance.
Dave
The solution is roughly the fifth post down in the tech library. Also an upgrade to a new Hvac control panel should do the trick though that will set you back a few shekels
