- Scottsdale
So, the headlights on my DD and the taillights on my H3 were a bit cloudy and I finally got around to addressing it. The best way seems to be lots of sanding and scratching but I also wanted to see if one of the new kits would help out. Still involves sanding/scratching of the lens, but perhaps less than the earlier kits required.
I went with Meguiar's G2000 Perfect Clarity Two Step Headlight Restoration Kit. It comes with cleaning solution (likely a version of a polishing compound), 2 3M Scotchbrite pads, and a sealing solution.
I taped off the area and used the pads with the cleaning solution for about 15 minutes to remove the buildup and scratch up the lenses. I wiped off the excess and then cleaned the lenses with plain water and a clean microfiber. Finally, I applied two coats of the sealing solution. The before and after:
They weren't bad to start but I didn't want them to get too bad.
Time will tell if these hold up to sun, rain, car washes, etc. The sealing stuff reminds me a bit of Wipe New in how it shines and protects. It's an aerosol so I recommend masking a much larger area than I did to avoid overspray.
Anyway, the initial results on both vehicles is good. I'll report back once these have been tested with the elements and time.
