Well... I think I may have some problems. Ive driven my H3 twice in the last 30 days. Both times, I throw the P0300 code every time I start it. Ive cleared the code, but it returns when I restart the truck. The truck seems to be running smooth, but is down on power, and my MPG have tanked to under 170 miles per tank. Now, I dont pay much attention to MPG, so that may be normal, as I have a winch, UCP, 35s, Gobi, etc etc. My ScanGuage shows Im getting 7-9mpg last I drove it on the highway.
Next problem, when the truck is cold, it makes a loud vibrating noise from the pass side of the motor. I think I have a bad exhaust manifold. I cant seem to find any crack. Once warmed up, the noise is gone. It does not sound like a typical exhaust leak (ticking)... so im confused.
Im still under my 100k powertrain warranty. Im getting a local shop I trust to handle the leak down test for me, as I dont trust the dealer.
Can anyone tell me if the dealer needs to remove any of the skid plates or UCP to replace the head?? I have repaired or replaced my crossmember EVERY time the dealer has removed my UCP because they zing the bolts with an airgun and strip them.
Should I remove my AirDoc before taking it in, as Im sure they will bitch about that or not re-install it correctly??
Has anyone had the exhaust manifold replaced under warranty??
Thanks
Thanks
