JTRX
- Northern Virginia
I installed the rocky road H3T sliders last night. All the pre-drilled holes lined up perfectly so bolting it on was easy enough. The sliders hit the front mud flaps so i'll either need to remove them or cut a slot for the front of the slider to stick through. The real issue though is that I'm not sure what to do about is the parking brake cable. The front attachment point pushes up considerably on the brake cable. The instructions say to move the vacuum collector to the rear attachment point but I'm not sure if that's what they're referring to. The parking brake cable mount is welded on. I'm assuming I'll need to move the cable mount but I was wondering if anyone had experience with this or any suggestions on the best way to prevent damage to the parking brake cable.
