h3 stuff
I'll be taking some stuff off here in the next few weeks so it'll be up for grabs...
* Bilstein 5100s - around 20k miles
-- claimed by CaseyS
* Trailduty extended bump stops
-- claimed by Graham2990 --
* Full set of hunner skids - you might have to grind some of the old hanger off the front ones
-- claimed by Tdavis --
* Outfitter designs diff bushing - the crossmember bushing only. Not the set of all 3
-- claimed by Pappibri --
* Warrior extended shackles - 2.5" longer than oem (1.25" of lift)
probably more stuff as I start taking stuff off but that what I can think of right now. Probably be ready to ship stuff out in early may. Just wanted to get it out there if anyones needing anything soon.
probably $80. theyre painted red now. the front 2 that are the welded to the sping hangers will be cut off when we do the spring over so they will probably need whats left of the hanger ground off and re-painted. i also trimmed off about an inch so it wouldnt hit the leaf spring at full droop. the back 2 that bolt under the leaf mounts are fine.
Pappibri
Cohoctah, MI
How much for the extended shackles... What kind are they? So how much if I get the shackles, and the Diff bushing?
$120 plus shipping for shackles and diff bushing. Will most likely fit in the same size "flat rate" box so they can be shipped together.
They are Warrior brand. forgot the exact part number. They are painted red right now.
Not sure. What are they worth to you? they're probably around $300 new. Generally speaking, I think you can expect 60k miles outta shocks +/- depending on use I guess so these are about 1/3 of the way through their lifespan. I'd say around $150 plus shipping. But with all this stuff, I'm open to offers. I dont want this stuff sitting around going to waste if someone else can use it.
those are the shackles im referring to. although the link you posted is not the right part number. and yes, they come in pairs.
I just found this on another forum. The ones I have are the 128s.
Just to be clear... I wasn't saying $120 for shackles. It was $120 for the diff bushing AND shackles. Prices are always negotiable.
