For what its worth, I have been waiting to get some shop time to install my airbag system on my H2. I got all the parts from airbagit.com, including an in-cab controller, etc.. I already have the tank and compressor installed, just need to find a place to mount the rest of the electronics and get the brackets installed. I have an extra airbag to keep as a trail spare, I wanted all the bags to be the same so if I had a failure it would be easy to swap out bags. Airbag it told me I most likely would never need the spare, because the bags are super strong, we'll see about that. I also have some schrader valves that I plan on intalling inline of each bag, after a check valve and the solenoids, this would give me the ability to manually adjust each bag in case the electronics fail.
Here is a pic of the new front UCA with a replaceable Moog balljoint and the upper bag mount that I need to weld to the frame. I defaintely like to try to swap the moogs out to uniballs.
There is no real kit for this, so its been in the works for quite some time. Anyway, here are a couple more pics with the tank before I finished all the plumbing.
Its been a big pain in my ass for the last two years, but I wanted to take my time with this setup planning, etc. before cutting/welding stuff up. I have a electronically controlled solenoid valve for each bag that will be controlled via an in cab controller that shows a digital pressure reading for each bag as well as the tank. Each valve can be controlled independently, just front, just rear, left, right, or all together.
Here is the controller I am using
Not excatly the same wiring/plumbing diagram/but close
Pair of solenoid valves look something like this, except my pressure transducer is built in
I'll get some pics up when I get back into this project and do a full build thread on it. I just want to take my time and do it right the first time. I have my concerns and hope not to sacrafice any suspension travel in the process. My biggest concern is trying to figure out a new place for the front shocks, since the new UCA and upper baf mount elliminates the OEM upper shock mount. There are definately pros and cons to this setup. Who knows It may suck ass once I'm done and I'll be back to the drawings board to figure something esle out, but its something to piddle around with for now.
