Garage - manufacturers, products, etc.
JGBB04
Tampa Bay
Here's a few more when someone gets a chance
Under Rigid Industries - E Series light bar
Under Thor Parts - Rear bumper
Add to manufacturer & pruchased from
Ram Mounts - Xgrip cell phone holder, GPS holder, Tab-Tite tablet holder
Braketron - Dash mount
Bump
abearden
N. Idaho
Knight Metal Works - Custom Bracket
Lubrication Specialists - Oil Cooler w/ Stainless & Teflon Lines
Glow Shift - Gauge Cluster
I'll do a few at a time as I get them done so I don't cause torture by 1000 drips.
JGBB04
Tampa Bay
will do. BTW, you can add items on your own and then we get notified for approval.
It might be my computer or IE but how do we do this? I remember seeing that option before (could have been the old site) but now I don't.
If I recall correctly - go to Add Modification, then click on "Not Listed?" and put in your requested manufacturer if that manufacturer is not listed. You'll have to wait for approval before you can add the item. Annoying, I know :huh:. But if your Mfr. is already there you only need to submit a new item.
You can do either route to add items - here or in the Garage, but for one or two items going through the Garage might be faster as other moderators can also approve them and you aren't waiting on me.
SolidusJ
FT. Carson, CO
-Jet High Flow Mass Air Flow Sensor
-Flowmaster 44 Exhaust
-Custom Side Tailpipe
-Bullydog Watchdog System
-Ac Delco Iridium Spark Plugs
-Black OEM Steel Wheels
-285/75/16 Dueler A/T Revo 2
-TRUXXX Shock Extenders
-Front Side Maker Light Grill
-Black Lug Nuts
-Black Out Lights
-Painted Front Grill
-Sound Ordnance B-8PT Single 8" Amplified Flatsub (X2)
-Rockford Fosgate RFK8I Amplifier Wiring Kit 8 gauge Power
-Sound Ordnance P-69 6"x9" 2-way Speakers
-Sound Ordnance P-65 6-1/2" 2-way Speakers
-Pioneer AVH-P4200DVD DVD Receiver
-PCM Tune
-PCM E-fan Kit
-Tsunami Battery Terminal
-FireStik 5 Foot Antenna
-Molded Antenna Side Mount
-MIDLAND 75822 HAND HELD CB RADIO
-Husky Mats
-Hunner Skids
-SMA Roof Light Bar (X2)
-48" Hi-Lift X-TREME Jack
-Hi-Lift Jack 4X400 4XRAC Jack Mounting System
-OEM Roof Bar
-Purple Cranim Spider Differential Rock Guards
-OEM UCP
-Rocky Road Rock Sliders
solidus, some of items above are already in the garage. Please go through the list and add those items to your truck as necessary. Other items may need manufacturers added to your list, like the antenna mount, lug nuts (aftermarket or custom?), etc.
JGBB04
Tampa Bay
While I'm in my bad mood pissed off at yet another dealer I'm still not seeing an option to add a manufacturer or item & I know the Garage is an unsupported add on but need at least 1 other person to confirm it or you guys are gonna be reading about another crazy nut job going off the deep end, the Captain isn't helping any more
No going off the deep end for you. Let me see if I can help.
1) Select your vehicle and choose "Add Modification" from the drop down list
2) Click on "Not Listed" to get a pop up window to add a manufacturer. If your pop-ups are being blocked, you may need to temporarily disable that blocker.
JGBB04
Tampa Bay
Thanks, that's not showing up for me on 3 different computers or my tablet, guess I've got some computer tweaking to do. now where did I leave that BFH
benlaud87
Maryland
that doesnt show up on mine either. maybe the forum settings are set to show that option for admins/moderators only?
I think we'll just open up the Garage where users can add their manufacturers and products w/o moderator approval. We do ask that you look for existing manufacturers and products before adding your own. We reserve the right to edit these items as necessary.
Sorry about the troubles!
benlaud87
Maryland
I like the idea of adding your mods then having some sort of approval, but I understand that takes time and can be a big burden on someone. Hopefully we don't start having the same mod added 12 different times just spelled differently.
Being able to add our own mods is great. It will probably lead to many smaller mods being added which can give others good ideas.
Sent from my A500 using Tapatalk 2
