FS: BRIGHT License Plate LEDs! Plug and Play installation! Same-day shipping!
Diode Dynamics
LED Lighting Experts
St. Louis, MO
Hummer License Plate LEDs! Plug & Play installation! Same-day shipping!
Hummer License Plate LEDs​
License plate bulbs are used to illuminate the rear license plate on your vehicle. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to LED, you can easily add this luxury look to your Hummer!
The installation is 100% plug-and-play, just replace your factory bulb.
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your Hummer looks at night.
Diode Dynamics offers several bulb options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens)
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of stock OEM bulbs! (92 lumens)
Bulb Design
SMD2: Similarly compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is One BULB (H2 / H3T uses only ONE).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
2003-2009 Hummer H2 License Plate LED
2009-2010 Hummer H3T License Plate LED
New HP3
If you have any questions, please don't hesitate to post, PM, or Email contact@diodedynamics.com
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Customer Submitted Photo:
New Jersey
I have LED on my back plate, but I'm not sure which ones they even are, and they don't seem to be as bright either, might be ordering a set from you soon brother
Diode Dynamics
St. Louis, MO
The new HP3's are perfect for this application, just the right amount of brightness IMO.
Don't forget to send us a PM for the free-shipping code!
Nick C.
Diode Dynamics
St. Louis, MO
Diode Dynamics
St. Louis, MO
[FONT=&quot]
[/FONT]​
[FONT=&quot]
[/FONT]
[FONT=&quot]Diode Dynamics’ Memorial Day Sale is going on NOW through Friday, 6/3.[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]Get 15% off all LED lighting upgrades with code "USA22" during checkout![/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]Plus, all orders over $300, will receive FREE shipping.[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]Click HERE to shop Diode Dynamics LED Lighting products![/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]Note: Products on pre-order (Elite Series Fog Lamps) are excluded from this sale.​
[/FONT]
