08SolarFlareH3
Super Swampers
- Finger Lakes, NY
GM Accessories #19159112 Front Mounted Off Road Lights
http://www.gmaccessorieszone.com/Hummer/en-US/H3/Electronics/Off-Road+Front+Mounted+Lamps/2008
List - $325.00
New in the box, never mounted. No harness or switch included but includes a copy of the install instructions which shows you the wires to tap into so you don't have to drill a hole in the firewall or run wires through the firewall. I also have a set of pigtails for each bulb that will be included, so you can make your own harness (just add a switch and relay of your choice). Also included is the wrench to adjust the angle of the lights and a spare 2nd set of new/unused bulbs. I can also help with a wiring diagram if needed and I can also help you locate a relay/switch (~$10).
$225 Shipped
List - $325.00
$225 Shipped
