H3 Exhaust pipe dimensions 07' H3
Hawkeye__8
Im looking to throw on a cherry bomb extreme to make it sound better. What is the exhaust pipe size near the end where it is welded onto the muffler? And would it be a good option to delete the resonator, or replace the resonator with the cherry bomb and run a straight pipe to the back? Any opinion and suggestion is appreciated.
Thanks.
K0PIR
Pierre, SD
I believe they're all two and a half inch. I looked at doing that, but I ended up leaving the resonator in and just swapping mufflers. A lot of people just get a cat back. I think I'll do that in a few years when my exhaust is shot.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
IISPEEDYII
Pennsylvania
How does that sound? I cut right at the res
K0PIR
Pierre, SD
I put in a Moroso spiral flow muffler and it sounds good. Not a lot of drone either. I tried it first with just the resonator and a muffler delete but there was too much drone for me. I didn't go straight out the back though, I just put a piece of pipe in where the OEM muffler was. Going straight out the back may have been better.
It's fun to experiment but I think in the long run I'll go with a cat back. SS and mandrel bends.
IISPEEDYII
Pennsylvania
Yeah I think I will be upgrading to the Gibson one
BradenGV
Texas
Just got mine installed on Tuesday, and I love it. On a 3.7 I5. Sounds deep enough, and not overly loud. I bought the 2.5" and took it to a local muffler shop and got it installed for $55.
They basically just cut out the original muffler, welded on the cherry bomb, and ran a pipe to make up for the difference (as the original is much much longer) Could get you a video if you wanted
Hawkeye__8
Can you get me a video on it? Im curious on how they did it. Thanks in advance
