Electrical problem
Hummerboy
Nc
I took my doors off when I went to put them back on I damaged it and had to take door panel off. Well I messed that up too and had to get it fixed the lock wouldn't work the speaker on driver door wouldn't work as well as door handle. After I got it back all the problems were fixed but now my power mirrors don't work and my turn signals in the front don't flash when I turn them on. the turn signal inside blinks really fast any help would be appreciated on how to fix
Woodtick
Ilanoid, UP MI
The turn bulb is burned out. Your mirrors are probably not hooked up to the switch. FYI , when the blinker flashes fast on just about any brand auto, it's a bad bulb.
Hummerboy
Nc
I just found it extremely odd that after they were done the two in the rear were blinking fast and the two in the front I had nothing
Hummerboy
Nc
Also just checked the lights do work... When I lock the doors the side markers and turn signal lights up but nothing when the turn signal is on.
What year is this "beast?" There was a slight wiring change after 06
Did you just turn on the lights and the bulb in the front works? Swap the bulbs from side-to-side and see if the problem goes to the other side. Those are dual filament bulbs so a light will shine in park/headlamp, but may not flash.
And not understanding the locking the door to get the lights to work.
I guess a lot more info might be needed.
Hummerboy
Nc
2006. When i turn the headlights on to on manually the daytime running lights come on as well as sidemarkers. when i say the doors lock and the lights flash i have it on the setting to honk and flash the running lights when locked. I would switch but neither turn signal works. is there wiring in the door panel for turn signals or is it just extremely coincidental they took the door panel off and now it doesnt work?
I can send you the wiring schematics for the items fed into the door.
Did you check fuse 56 (15 amp Front Turn Hazard Courtesy) that supplies power to the front turn signal bulbs? (Rear flashers go through fuse 20.)
It's a long shot, and not sure where you disconnected the doors at. But possible the turn signal wire was shorted and blew the fuse.
Hummerboy
Nc
please send them. I will check fuses if its not them the wiring schematics will help a ton to trying to solve it.
Hummerboy
Nc
Pretty sure I got it figure out sure enough it was the fuse as you can see in the pic both are blown. The second one was blown when I put it in spot 56 and turned on turn signal and tried to move my mirror with the button on the inside it moved then blew the fuse and the turn signals wouldn't work again. Don't know if that's normal but thought I would share if it ever happens to anyone else. Thanks f5moab next time I'll check fuses first just didn't think they would be an issue.
Fuse feeds BCM circuits for front turn signals and I believe the power mirrors?
Sounds like a short in one of the mirror circuits to the switch
