ecm question
Bheege78
New jersey
hello everyone i need some info on communication with modules! i have an 06 h3 i restored ground up for my wife it was hers she bought brand new in 06 and she is attached! i installed a 07 4.8ls motor upgraded the trans and did wire harness. i got a a e67 ecm that was supposed to be from 08 h3 alpha turned out it another v6 gm vehicle when i hooked up to my scanner through data link. i talk to a tuner in ohio and we agreed to try 08 alpha calibration with my 06 vin programing. i just got the modules back and now it doesn't pick up the ecm or tcm modules! i don't know why it read before i sent it out and now it doesn't! just curious if someone has some insight. i will call my tuner tomorrow and talk to him. i was just seeing some other opinions thank you
Bheege78
New jersey
In 06 the trans control module is part of the PCM, if I recall correctly. Midway through 2007 it went to two separate modules. Upgrading to V8s in an 06 is more difficult than with an 08. Read through 06 H3's engine swap thread and there may be info there. https://hummer4x4offroad.com/forum/threads/new-motor.9408/
Yes the 06 was pcm and I went to e67 with t42 tcm and I’m looking for someone with this set up to maybe give me some insight thanks
