- Central Texas
Website said something about losing an alternator also.
I like the system he's got for ctis. 4 air gauges ,lines marked for sand pressure and gravel pressure, toggle switches to inflate deflate each tire, and best part of it all instead of air tanks, the spare tires are just hooked into the system and act as air storage since they're already there. Wonder if a compressor is even needed.
Robby was not too happy with Nassir and the way he quit ,was not a team player and never listened to team orders and generally just drove in a way that broke stuff or almost crashed etc...even when he was told to back off a bit. In Dakar it takes more then being able to stomp on the gas pedal. Although he did win last year with that technique in turbo diesel VW buggie.
Just catching up on the DVR but I heard it as he broke 4 belts and gave up because something.. like the fan.. was breaking the belts and it would keep on happening.... Still keep goin till you run out of belts!He says he broke 3 others and that was the 4th broken one. So they know how to change a belt, but maybe didn't think to bring a dozen alternator belts.But even more shocking they say Robbie cheated by routing air from the tire inflation system. Into the intake beyond the restrictor plate. Now that's would be pretty sneaky. After all he was running against turbo powered stuff at high elevation, so makes sense. Robbie says he is not a cheater and that tube was only used as a way to deflate tires faster. He said he'd block it off and still be fast and that this in no way unfairly gave him an advantage. Sounds like American ingenuity at work...He's disqualified but can keep running on appeal that takes 3 weeks. Hummer being 2nd and stage wins sure was nice while it lasted.
