Custom winch mount!!
TAPDH3T
Texarkana, Texas
Hey guys I've been looking for a really nice winch plate for my T and have made contact with two really good machinist in my area.. After showing them a few pictures of the deflice winch plate and others they have both advised that they can do the job with no problem. I am waiting on a price quote of one of the machinist but I have spoke to both parties on a group discount.. I am just curious if anyone else would be interested in jumping on this and attempting a group discount!!! As of right now I am looking at just under $200 for the discount.. These can be made within a few days and be shipped in a week or so!! Just let me know!
I'm going tomorrow to see about going ahead and getting one built to show y'all.. The guy said he would need my truck for about two days and would have it done..
This is the final look we discussed!
ImageUploadedByTapatalk1358290363.079091.jpgImageUploadedByTapatalk1358290375.974219.jpg
SolidusJ
FT. Carson, CO
I think some of the others maybe worried about how low the winch will be. I was in some pretty deep nasty stuff but my winch was still above the water if I had to use it. Can't use a winch under water.
TAPDH3T
Texarkana, Texas
That's true!! When I meet with him tomorrow I will talk to him about that and see what his remedy is.. That's another thing! If u have questions or anything now is the time to ask cause he will be moding to our specs!!!
Low and between the frame rails is best for winching, but you have a higher risk running into water issues
I would be interested but I just got my winch mount
TAPDH3T
Texarkana, Texas
I know some winches claim to be waterproof!! Do those also have issues and would the waterproof gels over the terminals help?
ReconH3
Guardian Angel
Raleigh, NC
I've used my winch many a time completely submerged. They work fine. In the long run the internals will get messed up if you don't give it some TLC after a long submersion. That's the case with any mechanical parts that have been under water.
"Ex Umbris Venimus"
TAPDH3T
Texarkana, Texas
"Ex Umbris Venimus"
Thanks recon made me feel better.. I would buy a full bumper is I could afford one but with a baby on the way it's ruff!!
TAPDH3T
Texarkana, Texas
I'm just curious how much higher urs sets.. I think there is room to move this winch up atleast 2-3 inches without effecting the actual stock bumper...
TAPDH3T
Texarkana, Texas
Thanks Frumaker!!! I went and spoke to both machinist and both are Hummer Fans!!! The one I'm going with specializes in offroad parts and custom lifts.. He is interested in getting into the Hummer Brand.. He is willing to make an excellent deal if I have get him 2-3 sales.. He stated he can build it to look factory to our specs.. I'm taking y truck next week to get mine done.. He said he can have it done within a day.. If ur interested let me know so I can give him a heads up on material...
As a guy who has built many H3 bumpers (over 100)...I think you should check your math. Usually, a price like that means one of two things: A crappy fab job...OR the guy is working for free. Hopefully its the latter! Two-hundred bucks would barely cover the steel and powder-coat, much less the welding, grinding, and head-scratching. Its the head-scratching that really matters. The amount of time you spend tweeking your bumper design will directly result in how well it looks, and works on the trail. I'm all about saving money, and $200 is certainly a great price...and I assume you are getting free labor. If so...take it! You're gonna make that fab guy eat that quote! I can tell you a few things to be aware of, before you even start...
Unless you want to chop-up the stock plastic fascia panel, you'll be forced to place the winch low between the frame rails, Defelice style. This will limit you to a winch with a small physical size....such as the Warn M8000 (that comes with the Defelice bumper). Some of the newer model 9500 winches might fit but, it will be tight for sure. Remember, you gotta put the control box somewhere as well. It would be a good idea to have a couple winches with you when you drop off the truck at the fab shop. Its tight enough under there, that you will need an actual winch to build from. You won't be able to build it Jeep style...and simply leave room for the winch. We're talking about fractions of an inch, and most likely...the make and model of winch you end up with, will be determined by its physical size (and not by what you want to use). BTW...an 8000lb winch is completely suitable for an H3. Given the location you're trying to use...you can't get winch-happy. Smaller is better.
If you don't mind cutting on that plastic fascia panel...you might be able to mount the winch ABOVE the frame rails. This would put your fairlead approximately where Recon's is, and also allow you to use larger winches. The protrusion of the winch motor will be the determining factor, and positioning it above the frame rails means the motor is free to grow outboard past the frame rail...something that can't happen if you're trying to keep everything confined in the bumper area. So, you need to decide early-on if cutting apart your fascia is an option. It will certainly open up more winch choices, and also make fabbing easier too.
