telemike
Hummer Enthusiast
- Greensboro, NC
I have an early 2007 H3 Adventure with the older style door switches. Is there a VIN# or build date when the plastic fork was updated?
In regard to production changes, yes, GM engineering should have a record of every change made to every component, but it would not be known to a dealer database, unless it was made part of a product bulletin. The record is needed in case of a future recall, they have to know what vehicles to recall with certain items. (I say should, since the last days of the old GM was a cluster F and who knows what was going on in Shreveport.)
Forgot to add, unless your t/case has been rebuilt, you have a 100 percent chance of having the plastic shift fork. And there is more to it for all 2006 and early 2007 H3s and it is in regard to t/case fluid fill levels.
If your VIN is 56TDN13E778100102 or earlier, you need to add fluid through the VSS hole; not the fill hole. Unless your t/case has been replaced by a later model t/case.
I believe I posted all this info on this site earlier in regard to this screw up by BW.
Why not? Why start a whole new thread when there is one already started that could have valuable info, thst I or someone else would not have seen. Plus why have multiple threads about the same thing? Continue an old thread makes searching easier as you don’t have multiple threads to search for and read through. This forum and the other Hummer forum are the only ones I’ve ever been too that gets so bent on someone searching and posting on an old thread.What I don't understand is the need to keep dredging up old thread! Start a new thread and link this old ass one to it.
IMHO
i'm in this camp. that's why forums have search functions.Why not? Why start a whole new thread when there is one already started that could have valuable info, thst I or someone else would not have seen. Plus why have multiple threads about the same thing? Continue an old thread makes searching easier as you don’t have multiple threads to search for and read through. This forum and the other Hummer forum are the only ones I’ve ever been too that gets so bent on someone searching and posting on an old thread.
The best part of any forum is its historical cataloging of content & its value. Especially a forum like this where the main topic (Hummer) is obsolete and your best friend is historical information.
my 08 had a plastic shift forkI don't understand.
Did GM replace the shift fork on 2008 or later H3s? Or were ALL 2006-2010 use plastic forks?
