H3 Undercarriage Protection, NIB $350 + shpg
S
SedonaBound
For Sale: H3 Undercarriage Protection, NIB $300 + shpg (reduced)
​Factory GM Undercarriage Protection (aka UCP or Underbody Shield) set for 2006-09 Hummer H3; new in box, never installed.Traded our '06 H3 before I got around to installing it. Consists of two-section bolt-on welded tubular steel protection for the drivetrain. These sets do not fit 2010 models.
$300 + shipping from 86336 Sedona AZ or pick it up. (approx. 50 lbs.)
That's not a bad price. However, the OEM GM UCP set does fit the H3T, as I have them on my H3T. They fit both the H3 & the H3T.
Where did it not fit? Do you have a Rancho or Tough Country lift kit on your T? If so, the front shield (the one that protects the tranny) will not fit) but the one that protects the transfer case will. If you don't have an after market lift kit they should fit unless the '10 T frame crossmembers are in different locations than the ones on the '09 T. :huh:
racer3822, more info please.
skeptic
Orygun
I have (what I believe is) the OEM GM UCP on my '09 H3T - no issues installing it. I don't have a lift kit on my T if that matters.
I just remebered what the difference is with the '10 H3 & H3Ts - they came with the new/"updated" front diff crossmember that did not have the UCP tab welded on the passenger side to bolt the UCP onto. This is not an issue with just the 2010 H3T, as it also affected 2010 H3s that came with the new crossmember version.
On those H3s/H3Ts with the "updated" front diff crossmember that welded tab is missing from the crossmember and the front ucp shield sits between the cross member and the steel engine shield/skid plate. All you need to do is use a bolt and connect the shield/skid plate to the tab that is on the UCP shield and you are good to go. Any pressure on the ucp shield is only going to push it into the cross member so it's not like your losing any structural strength, it's not perfect, but it should withstand some pounding.
Another option for those with the "updated" crossmember having this issue with the UCP and not having the welded UCP tab to bolt to, tawould be to get a Scorpworks crossmember (you will be needing to replace the crossmember bushing anyway). All Scorpworks "updated" crossmembers come with a UCP tab welded to the crossmember.
S
SedonaBound
...However, the OEM GM UCP set does fit the H3T, as I have them on my H3T. They fit both the H3 & the H3T.
One buyer tried it on a '10 H3T and it did not fit. The H3T fitment is not clear so I won't describe it as anything but an 06-09 H3 UCP.
racer3822
Corona
The bar in the back that the UCP bolts to, and the skid plate in the front that it bolts to are too far apart. It wasn't able to meet in the middle like it's designed.
I have a H3T Alpha, so I'm not sure if the V8 has anything to do with it either because I know some things were changed to fit the V8. I snapped a photo, even though I didn't have the hummer lifted up so it's not that great.
I believe you either have that front piece facing the wrong direction by 180 degrees, or you received a mismatched set. Granted the pieces in my pic below are a tad bit worn, but I think you can see the forward piece looks much different.
By the way, notice how straight the OEM UCP is?:huh: It was last repaired/straightened about 18 months ago, meaning it's had at least three trips to Moab and a bunch of other trails in that time. Not perfect, but it holds up pretty well.
The longitudinal bars "stick out" towards the front of the truck, not towards the rear as they do in your pic. This pic isn't super clear, but does show that orientation to some extent. The tire in the background is the driver's front tire, so you're looking at the very front of the OEM UCP, from the driver's side on the bottom left to the passenger side on the upper right.
racer3822
Corona
I actually did try to flip it around 180 degrees and line up the bolts the other way. I don't recall it making any difference the distance was still too long, it was too short either way. Maybe I snapped a photo after I turned it around, I'm not sure at what point I did.
I suppose it could be user error, but I do have a 2010 H3T Alpha and there are reports that model has different spacing, right?
I have not heard of any different spacing for 2010 vs. other years. The engine, transmission and transfer case all have fixed mounting points, and those components did not change from 2008 to 2010. Alphas of course use different engine mounts and I believe had a bit of firewall clearance performed, but those changes were done in 2008.
My OEM UCP was difficult to install on my truck as I had already banged up the undercarriage so it took some force to make things work but the bolt holes were close and off maybe 1/8"-1/4". Either way, that front piece is backwards and/or improperly manufactured.
As Bigunit said, on the very front piece, passenger side, you may not be able to line up with the crossmember but just with the skid plate. The bolt hole in the driver's side front should line up.
S
SedonaBound
It's still here. What's your zip? I need it for getting the exact shipping cost. Is the address a residence (need for UPS)? Also let me know how do you want to pay, so I send you the right info. If you use a check, I have to wait 'til it clears before shipping. If you use PayPal, I can ship it as soon as the payment hits PayPal..
Cheers
Dennis
ABN if he can't wait I will buy it and have him hold it for you. I don't think that is an issue. Sedona are you ok with waiting on the payment?
