I found it very easy to wire these lights without an OEM harness, though if you use the OEM switch you do want the pigtail. The pigtail has three wires marked A, B and C. One is ground, one is 12V power, one is to the relay (don't remember which is which at the moment but I'll update this later). For the 12V we tapped into the 12V accessory power (cigarette lighter). Ground was one of the studs in the firewall under the dash holding the dash components in place. And of course the relay wire went to the relay.
You can buy the Weatherpack connectors used on the H2 lights or even cut them off and use your own though the Weatherpacks are very good.
As discussed in IndyHummer's new thread I recommend going with a distribution block if you are going to have several accessories to the battery.
:link: This will allow you to wire more cleanly and keep your battery from being overrun by wires. Another option is that you can use an Add A Fuse and plug it into a spare spot in the fuse block. I think we used #15 which is the spot for the OEM off road light option.
If you haven't wired a relay before it is pretty easy. There are four (or five) terminals on the bottom. You need four:
85 - ground (Use the ground on the fenderwall by the battery, or use a distribution block)
86 - switch (from passenger compartment)
87 - light power (positive power wire to light)
30 - 12V power from battery/distribution block
Lights - power goes to #87 on relay, ground goes to ground point on fenderwall.
