Diode Dynamics
LED Lighting Experts
St. Louis, MO
Featuring higher output intensity than any other 2” light on the market, these LED pods have been designed for maximum functionality, with custom-engineered TIR optics shining in highly useful beam patterns, all in a durable package.
Focused. Traditional optics like reflectors or simple lenses lose light internally and to glare, so not all of the light shines on target. Instead, the custom-engineered TIR optic in the Stage Series 2" collects all of the light from the LED, and directs it only where you need it, drastically reducing glare and improving total efficiency.
From there, while other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the Stage Series 2" serves as both the optic and main lens for greater efficiency and light output (patent pending). Thanks to this innovative feature, when coupled with high-intensity LED chips, the total intensity of the Stage Series 2" is much greater than other LED pods using basic optics or reflectors with a standard outer lens.
Functional Patterns.
All Stage Series beam pattern options were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern. No matter what your auxiliary lighting needs are, there is a Stage Series optic for you! Click here to learn more: Beam Pattern Comparison Video.
  • SAE Driving is designed to supplement your high beams, but it’s great for general illumination as well. Rather than a traditional "spot" pattern, the Stage Series Driving pattern shines in an 18x8 degree spread, providing just enough width to fully illuminate the road ahead at high speeds.
  • SAE Fog provides an extremely wide field of view, with high-intensity output over an entire 80-degree spread. It serves as a great upgrade for any factory foglamp, and will fully illuminate the area in front of your vehicle. Choose your output color of cool white or yellow, which is often said to help cut through inclement weather.
  • Flood pattern was designed to provide uniform, even illumination with a full 60x60 degree spread of light. Unlike generic "flood" lights that are simply a heavily diffused spotlight, our flood pattern uses pillow optics on the outer lens surface, to provide a true optically designed spread, for even illumination throughout. It is perfect to use as a backup light, for lighting up anything at low speeds, or for trailers and worksites.
  • Combo pattern combines both the Driving and Flood optics. It shines light downrange in a focused, rectangular 40x20 degree pattern. The combo lens features a flood optic on one side and a driving optic on the other.
  • Spot is an unmodified pattern, shining light directly from the TIR optic. The result is a highly focused 6-degree beam of light, perfect for directing light far into the distance.
Not just off road. When installed as a pair and aimed in accordance with your state's regulations, the Driving White pattern meets SAE J581 standard as a Driving/Auxiliary High Beam Light, and the Fog pattern meets SAE J583 standard as a Foglamp, for legal on-road use.
Interchangeable Lens. Need a different beam pattern or color? You can swap it yourself! We offer replacement lenses that allow you to change the color or optic of your Stage Series SSC2 Pods.
Snap-on covers. For states that require them, or for extra styling or protection, we also offer snap-on covers for your SSC2 Pod. These covers are available in a variety of colors and keep your SSC2 Pod clean and protected from dirt, dust, or whatever else the road throws your way!
Please check your local laws and regulations for aiming, installation, and applicability.
White or Yellow. All Stage Series LED pods are available in a cool white or selective yellow color. The white is a 6000K color temperature, which is a true cool white output, and matches most factory LED lighting. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a distinctive look on the road.
Sport or Pro. Stage Series LED pods are available at two different power levels. Both options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. However, the Pro option is double the amount of total power.
Backlight Functionality. The Stage Series 2" LED Pod includes a distinctive backlight feature, in your choice of white, amber, red, and blue.
The SSC2's backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.
NOTE: Due to the yellow lens, the Yellow SSC2 LED pod is only available with an Amber backlight color.
In the Box:
  • Two (2) Stage Series 2" LED Pods
  • Two (2) Deutsch-style wire pigtails
  • Two (2) Mounting brackets and hardware
Simple connections. All Stage Series 2" LED pods feature a custom-molded DT type Deutsch-style connector on the back, and come with a 6-inch pigtail with bare leads. For installation, you can wire yourself, use an off-the-shelf Deutsch DT sized wire harness, or select an optional Diode Dynamics wire harness. Our Heavy Duty Dual Output 4-Pin Harness can be used to power up to four Stage Series 2" pods.
Proven Reliability. Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
If you have any questions, please don't hesitate to post, PM, or email contact@diodedynamics.com.
PM us for the free-shipping code (U.S. forum members only)
John C.
Diode Dynamics
Diode Dynamics
St. Louis, MO
Diode Dynamics
St. Louis, MO
[FONT=&quot]
[/FONT]​
[FONT=&quot]
[/FONT]
[FONT=&quot]Diode Dynamics’ Memorial Day Sale is going on NOW through Friday, 6/3.[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]Get 15% off all LED lighting upgrades with code "USA22" during checkout![/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]Plus, all orders over $300, will receive FREE shipping.[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]Click HERE to shop Diode Dynamics LED Lighting products![/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]Note: Products on pre-order (Elite Series Fog Lamps) are excluded from this sale.
[/FONT]
Diode Dynamics
St. Louis, MO
Our July 4th Sale starts NOW! Today through Friday, 7/8/2022, save 15% on all LED upgrades by entering coupon code "JULY4" at checkout!
Plus, all orders over $300 will receive free US shipping.
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 7/8/2022. Cannot be combined with other coupon codes.
Diode Dynamics
St. Louis, MO
THE CLOCK IS TICKING!
Hurry! There are ONLY 3 DAYS LEFT to save on your favorite LED lighting products from Diode Dynamics.
Click HERE to shop!
John C.
Diode Dynamics
Diode Dynamics
St. Louis, MO
Did you know?
The Diode Dynamics Stage Series Flush Mount Reverse Light Kit is universal.
Plus, it's offered in your choice of our SSC1 or SSC2 LED pods!
Interested in learning more? Check out the YouTube video provided below!
Acer4LO
Illinois
I bought a pair of SSC2s when you guys were having your 4th of July sale! 😁 Haven't installed them yet, but I tested them out, and they are bright! Only thing is, the backlighting on them seems to be dimmer in real life vs when you take a photo of them or see pictures of them online. Can't wait to get them installed tho!
Diode Dynamics
St. Louis, MO
Good morning,
We apologize for the backlight concern. The intensity of our backlight varies on the optic paired with our products. For example, the SSC2 LED pods you've selected is our "spot" optic which doesn't include any diffusion on the lens for the light to shine as intense as a "flood" or "combo" optic.
The video provided below is a great example for comparing our optics and how they affect the include accent light built inside.
If you need assistance or want to exchange products. Please go ahead and give us a call at 314-205-3033 Monday-Friday 10 a.m.- 5 p.m. CST, or shoot us an email at contact@diodedynamics.com, and our service team would be happy to help you with that!
Acer4LO
Illinois
Good morning,
No problem! Thank you guys for clarifying this! I think the spot lens version is going to the best for my above-the-windshield application, so I will stick with it. I do like how the SSC2s have modular lenses so if later down the line if needed, I could swap for a different lens. Thank you guys! Your products are great!
Diode Dynamics
St. Louis, MO
As many members know, the lighting industry as a whole is still facing many challenges due to current market conditions.
All the more reason to give a HUGE shoutout to our production and supply team who are quite literally on a RECORD pace of output this year!
CLICK HERE TO SHOP
Diode Dynamics
St. Louis, MO
Our Labor Day Sale starts NOW! Today through Friday, 9/9/2022, save 15% on all LED upgrades by entering coupon code "LABOR22" at checkout!
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/9/2022. Cannot be combined with other coupon codes.
Diode Dynamics
St. Louis, MO
Our Black Friday Sale is LIVE! 🚨 Visit the website for our BIGGEST savings ever!​
20% OFF Sitewide
30% OFF Stage Series Single-Row Lightbars
15% OFF Elite Series Headlights
➡ Free US Shipping on any order with a HitchMount LED Pod, or orders over $300.
No coupon code is required.
Click HERE to shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday, 11/29/2022. Cannot be combined with other coupon codes.​
Diode Dynamics
St. Louis, MO
Our BIGGEST and FINAL sale of the year ends tomorrow 11/29 at 11:59 pm CST!
20% OFF Sitewide
➡ Plus, orders over $300 receive free US shipping!
Excluded Products:
Hitch Mount LED Pods (Includes free US shipping)
CLICK HERE TO SHOP!
John C.
Diode Dynamics
Sale ends at 11:59 p.m. CST on Tuesday, 11/29/2022. Cannot be combined with other coupon codes.
Diode Dynamics
St. Louis, MO
⌛THE CLOCK IS TICKING... ⌛
NOW
is your chance to SAVE up to 15% sitewide on your favorite Diode Dynamics LED lighting products.
Up to 15% OFF LED Lighting Upgrades
➡ 15% OFF Stage Series Rock Lights & HitchMount LED Pods
10% OFF Elite Series JL/JT Headlights
➡ Free US Shipping on any order over $300!
CLICK HERE TO SHOP NOW
Did you know?
You can find all of the products we offer for your vehicle using our vehicle finder tool! Simply enter the year, make, and model.
SALE EXPIRES 11:59 P.M. MONDAY, MARCH 13TH, 2023.
Discounts cannot be combined with other offers or any previous orders. Excludes items with pre-order status.
Diode Dynamics
St. Louis, MO
We get the question "how do the SSC2s compare to other options on the market" a lot. Today we answer that! In this video, we compare our SSC2 2" LED Pods to other market-leading 2" Pods! We break down each pod by intensity, beam pattern, power level, and price.
For this comparison, we've used our state-of-the-art Goniophotometer, a device that measures multiple points to calculate the intensity and map out the beam pattern of each 2" LED Pod option these brands offer! We hope the data we collected helps you choose the best pod for your vehicle!
Diode Dynamics
St. Louis, MO
For a limited time, you can get a FREE dual-output backlit wiring harness (DD4092) valued at $40 with every pair of universal SSC1, SSC2, or SS3 backlit purchased!
But you'll have to hurry - this offer is limited to just 1000 harnesses and is first come, first serve! Adding pods to your cart is all it takes - no coupon code is necessary.
This offer ends May 5th, or while supplies last! Take advantage of this deal TODAY!
CLICK HERE TO SHOP
Diode Dynamics
St. Louis, MO
Time is running out!
Get a FREE dual-output backlit wiring harness (DD4092) valued at $40 with every pair of universal SSC1, SSC2, or SS3 backlit purchased!
Click HERE to shop Stage Series LED Pods!
Just a reminder, you can use the code provided below for free US shipping for the remainder of the month.
Free US Shipping Coupon Code: MAY01
Diode Dynamics
St. Louis, MO
🚨 Our Memorial Day Sale is LIVE!!! 🚨
➡ Up to 15% OFF Sitewide
10% OFF JL/JT Elite Series Headlights
➡ Free US Shipping on any orders over $300!
Excluded: F150 Elite Series Headlights, and F150 Elite Series Fog Lights
John C.
Diode Dynamics
Hours: Monday-Friday 10 a.m. - 5 p.m.
Email: contact@diodedynamics.com
Phone: 314-205-3033
Sale ends 11:59 p.m. CST on Friday, 6/2/2023. Cannot be combined with other coupon codes.
Diode Dynamics
St. Louis, MO
⏳ WARNING! TOMORROW IS THE LAST DAY TO SAVE! ⏳
Up to 15% OFF All Lighting Upgrades
FREE US Shipping on any order over $300!
Click HERE to shop lighting upgrades for your ride!
🚨 Sale ends 11:59 p.m. CST on Friday, 06/02/2023. Cannot be combined with other coupon code 🚨
John C.
Diode Dynamics
Phone: 314-205-3033
Diode Dynamics
St. Louis, MO
It's our LAST SALE of the summer!
Save BIG on premium US-assembled lighting sitewide!
The time to upgrade is NOW!
20% OFF Single Row Stage Series Lightbars
10% OFF Sitewide
FREE US Shipping on orders over $300!
The sale ends Friday, 9/8.
*Exclusions apply. While supplies last.*
CLICK HERE TO SHOP YOUR RIDE AND SAVE!
Did you know?
You can find all of the products we offer for your vehicle using our vehicle finder tool on our website! Simply enter the year, make, and model and all options will appear.
