Anybody know how large the eHummer will be?
I haven't been able to get a real sense by the videos or images, but it looks like the new Hummer will be larger than the H3. Are there specs that were released?
650Hawk
It's likely wider than a normal full size truck, since the 3 center marker lights front and rear are required for vehicles over 80" in width. Similar to a Ford Raptor.
The GMC Hummer EV pickup has a wheelbase of 135.6 inches and a total length of 216.8 inches. This makes it shorter length-wise than a, GMC Sierra 1500 Crew Cab Short Box, which has a wheelbase of 147.4 inches and overall length 231.7 inches.
[FONT=&quot]While the Hummer EV pickup isn’t quite as long as a light-duty Crew Cab pickup, it’s notably wider. A GMC Sierra 1500 Crew Cab Short Box is 81.2 inches wide (not including the side mirrors) and GMC Hummer EV SUT is 86.7 inches wide without the side mirrors.[/FONT]
[FONT=&quot]
Standard SettingsTerrain ModeExtract Mode
Wheelbase (in. / mm)135.6 / 3,445135.6 / 3,445135.6 / 3,445
Length (in. / mm)216.8 / 5,507216.8 / 5,507216.8 / 5,507
Width w/o mirrors (in. / mm)86.7 / 2,20186.7 / 2,20186.7 / 2,201
Width w/mirrors (in. / mm)93.7 / 2,38093.7 / 2,38093.7 / 2,380
Max ground clearance (in. / mm)10.1 / 25711.9 / 30215.9 / 404
Front overhang (in. / mm)34.7 / 88134.7 / 88134.7 / 881
Rear overhang (in. / mm)46.5 / 1,18146.5 / 1,18146.5 / 1,181
Bed length (ft. / m)5.0 / 1.55.0 / 1.55.0 / 1.5
Approach angle (deg.)41.544.349.7
Departure angle (deg.)31.633.738.4
Breakover angle (deg.)22.325.432.2
Climbing angle (deg.)60.060.060.0
Wall climb (in.)18.018.018.0
Water fording depth (in. / mm)26.0 / 66028.0 / 71132.0 / 813
Track width f/r (in. / mm)73.3 / 1,86373.3 / 1,86373.3 / 1,863
Turning circle – 2WS (ft. / m)44.3 / 13.544.3 / 13.5-
Turning circle – 4WS (fr. / m)37.1 / 11.337.1 / 11.3-
Suspension travel f/r (in. / mm)13.0 / 33013.0 / 330-
[/FONT]
Source:
https://gmauthority.com/blog/2020/1...mer EV pickup,and overall length 231.7 inches.
SlcHummer
Salt Lake City, UT
[FONT=&amp]While the Hummer EV pickup isn’t quite as long as a light-duty Crew Cab pickup, it’s notably wider. A GMC Sierra 1500 Crew Cab Short Box is 81.2 inches wide (not including the side mirrors) and GMC Hummer EV SUT is 86.7 inches wide without the side mirrors.[/FONT]
Damn, wider than the 86.3" raptor and 86.5" h1
