SASd H3 Sway Bar Setup
Korby7
Utah
Has anyone with a solid axle conversion figured out a sway bar setup yet? I think I have one figured out but would like to hear what others have done. I have an Anti-rock that I'm thinking of routing through the frame just behind the front body mounts. I'm looking at installing a dedicated cooler for the trans and then a custom radiator that I can re-route the lower radiator hose to make a path for the sway bar. I still may have to modify the arms and disco when on the trail. Thoughts?
I’ve tried & gave up at least four times (including a Currie anti-rock). I can’t get the DS arm past the steering box. The pitman arm swings into it.
I had an FJ80 sway bar mounted on the back of the axle tube. It worked but ultimately took it off because you couldn’t use a quick disconnect. The bar got into the rocks and would get destroyed.
Korby7
Utah
I’ve tried & gave up at least four times (including a Currie anti-rock). I can’t get the DS arm past the steering box. The pitman arm swings into it.[/QUOTE
I was afraid of that. I found a post of an FJ80 that hopefully has the answer. The front end looks pretty similar to me. He was able to fit an anti-rock sway bar. He’s got an FJ80 pitman arm (supposedly fits the FJ60 box as well) with a jog in it to the passenger side that allowed him to clock it a couple of splines and still clear the track bar mount. He then Z shaped the arms to clear what impact area on the pitman arm was left. The arms sit close to the tire at full clock but they do appear to fit.
Here’s the link with pictures.
https://forum.ih8mud.com/threads/how-to-add-a-front-aftermarket-sway-bar-to-your-cruiser.1024576/
Do you see this as being a possible option? If so, I’ll give this a go and see where that takes me. Having a hard time sourcing the pitman arm though. OP was no help at all.
I know him! We chat pretty often. I can reach out to him if you want if you have more specific questions
Korby7
Utah
Thanks! If you can get more out of him, a part number would be great!. He let me know what the post already said, its off an FJ80, but all I can find based off that is drop or straight arms. I had one possibility out of Dubai for $400 plush freight but the pictures weren't great so I still wasn't sure it was what I'm looking for and that's a crap ton for a pitman arm. I'm sure there has to be one cheaper in the states.
You could consider custom-bending your own. Way back in the 80's when I was 17-18 years old I had a classic car as my first car. Back then there weren't the suspension companies there are now, and it was impossible to get a stout sway bar to fit my mid-size car application. I had a lot of tools at my disposal; I took a torsion bar (Torsion bar ...not, anti-sway bar), out of a full-sized GM car (Toronado), which were 1 1/8" diameter and pretty long, long enough for what I wanted to do. I heated er up and bent it accordingly to fit one bend at a time. After each bend I quenched the bend area in oil. I did an initial dip, removed for no more than a couple seconds, then diped/soaked it till cool. This was per a friend of the family at the time who worked at a foundry (I'm sure there are youtube videos on best quenching techniques). Then drilled the ends to suit. It performed flawlessly and never lost it's shape or form. Then I took the existing 5/8" sway bar (that was originally on the front of the car), made a few mods and installed it on the rear of the same car. Add some cast aluminum wheels, slightly heavier duty springs, and let me tell you, I had the best canyon-carving early 60's car in the COUNTY!!
I also did the same thing for another vehicle I bought a few years later that had the typical 60's terrible suspension. Again, never lost shape or rigidity, cornered flat as could be. GM trucks use torsion bars, should be plentiful. But might not be thick enough for what you want to do. Unless you can find one out of a HD or 3/4 ton/Dually (do they use torsion bars?).
I bet a guy can probably buy the right length and thickness sway bar stock (solid or hollow) from some of these sway bar companies and custom-make your own. Or, if you bent what you needed in, say, 3/4 or 1" EMT conduit or black pipe ...bend it up so it fits your custom H3 front suspension ....then send it to a sway bar company, you can probably work with them to duplicate the shape for you in whatever thickness you need (they can probably do the calcs and suggest a thickness). Or I wonder if it's possible to modify your H3's existing anti-sway bar?
Another option, if you off-road a lot and don't mind spending a few bucks, is to consider a remote anti-sway unlock/lock system like the Rubicon and Gladiator use (the Bronco will use one too they say). I forget the company name who makes them, but just do a google search. Should be able to come up with something.
Anyway, don't give up. Those are some ideas for ya....
Good luck.
Stock 80 series pitman arm
Korby7
Utah
Thanks for Taking the time to ask him. I get a few different part numbers when I search for that. I may have found one in [FONT=&quot]United Arab Emirates. It’s priced way better than the one I looked at last time I searched. I’ll try my luck with that one I guess. Thanks again.[/FONT]
I’ve made a few custom pitman arms. Start by cutting the splined end from a donor pitman arm. Machine it down to a small donut...with the Toyota splines intact. Cut your new arm from some billet stock and bore a hole in it for the donut. Drop it in and weld it up. Toyotas are easy because there are no master splines.
Also...I just dug thru my pitman arm pile. Is this the one you are looking for?...
This has already been reamed for a 1-ton DRE (top down). Let me know...I can ship it out to you. $75 shipped.
Korby7
Utah
Unconventional looking but I modified a universal Currie sway bar kit with some 1/2” thick arms that should clear up travel to bottomed out bump stops and 6” droop for on-road use and swing out of the way for trails. Still have to fab up the disconnect link and axle side bracket for the passenger side before I’m able to test but I’m excited and hope this changes the road manners a bit. Next is a new drag link with the pitman arm from 4 Speed that could eliminate impact points completely. A work in progress.
Slightly off topic. But any more details on that front cross member you've got there? The one right ingrint of the engine oil pan? I've got a rudimentary bar by the rad but want something better
Korby7
Utah
This is the best shot I’ve got of it on file. It jogs up and bolts on the inside of the drivers side frame rail. Bolts are shared with the steering box. On the passenger side, we welded a gusseted bracket on the inside of the frame rail that the crossmember bolts to. It comes out should I need to drop the engine. The 1” straps coming off the front of it support the power steering cooler. I can shoot you some more specific shots if you need some.
Korby7
Utah
genius idea on the sway bar, did you make that?
Thanks, coming from someone like you who’s seen so much, that means a lot. I mocked it up with different wire and cardboard templates until I was comfortable enough to go for it. I used the spline section off the universal Currie/Rock Jock kit welded to my patterns I cut out of 1/2” plate with an eBay special plasma cutter. I put a slight bend in it to clear the steering box with a modified Harbor Freight 20T press brake. I may make some changes to get the links more vertical. Weather and work permitting, I hope to get a road test in the next week or two.
Reloader
Montana a free state
What width Currie Antirock universal kit did you use? I went with Fox coil overs and it definitely needs a sway bar setup . The stock rear sway bar with longer links helps.
Korby7
Utah
[FONT=&amp]I used Currie CE-9906-21. It’s 50” kit which seems to be the perfect width.[/FONT]
I've finished the install and put some miles on the setup. Having no experience with anti-rock sway bars, I don’t know exactly what kind of performance to expect, but I’d say I have about 50% of the factory stability back which is not what I hoped for but I’ll take it. If I went back to the drawing board I’d extend the arms a bit and design home location for longer links. Part of my issue could be coil spring choice. We used Pro Comp 55617 springs for a JK which aren’t a great match for the weight of the V8, let alone the weight of the THORPARTS bumper and steel cable winch. I’ve got a set of coil springs for a Bronco that 4-speed recommend (shoulda listened) that I may put on that’ll require some mounting modifications to fit. I’m also looking into some Toyota 80 series springs that l think could work with no mods. Identifying what size of those has me nervous on pulling the trigger on any.
Reloader
In the 50” kit is the torsion bar actually 50” long? That would put it too close to tires when turning. Looks like 40” would be perfect length.
Reloader
Oh and I have a set of original Toyota FJ80 front and rear coil springs in my collection of stuff. They came off our 93 FJ80 when I installed a Slee 5” lift kit last fall.
Korby7
Utah
You are right, sorry. I just spit out numbers off the original link that I used but I just measured and I went with the 36"option.
I've been looking at getting Slee coils. Seems they're the go to for the FJs. I just don't know how to figure what size lift coils I should be getting. The JK coils I'm using are about 21" uncompressed and 16" at ride height. The Bronco coils I have are 18 1/2" uncompressed. How long are your stock FJ80 front coils?
Korby7
Utah
I've gotten a lot more seat time with the front sway bar setup and notice it plenty as I hit familiar turns. I'll probably leave it as is unless I have the sway bar flip on me because the short links. I don't see that happening under normal road conditions but I'll redesign for longer links if it does.
For Slee coil springs, I can only find 4" lift that are about 19.22" and 6" lift that are 21.85". I think I'll try the medium 6" lift coils and adjust the spring buckets if I need.
