- Tardville
$3000...must be picked up in Indy. Specs below..
Specs below...
Can provide additional SAS items if desired (Frame plates, driveshaft adapter, frame brackets, link bars, springs, shock towers, steering system, trackbar, tie-rod, drag-link, shocks etc.) Can also make mods if desired (re-gear, lockers, shafts, etc.).
Specs below...
- Stock large-tube GM Dana 44 housing
- Stock GM 3/4-ton shafts 30 spline inner/19 spline outer
- New Spicer ball joints
- New Spicer u-joints
- All new bearings & seals throughout
- GM flat-top knuckles (required for crossover steering)
- Spicer 4-series single-track diff with 4.56 gearing
- Ford strap type yoke
- THORparts ABS hubs (accept your stock H3 brake system)
- THORparts 3-link coil-spring brackets (pre-welded)
- Warn Premium lockouts
- 1/4" steel rock cover
