Gen 1 Thor Bumber
SolidusJ
FT. Carson, CO
If anyone is planing to upgrade from the Gen 1, let me know an I'll make and offer for what you got!
SolidusJ
FT. Carson, CO
Are you looking for the bumper itself or just the light pods and grill for example?
I remember the light pods bolted up the radiator support or something like that, I'm just not into the new look with the Gen 2. I ripped off his idea with my first bumper but I'm planning to just with his style with the new T.
I've got a set of the new pods coming today, so I'll have my old ones available if that is what you are looking for, but not the bumper itself. I'll still be using that and swapping it over to my Alpha and adding the Gen 2 pods to it.
SolidusJ
FT. Carson, CO
That should work, the winch mount is still the same right?
Yeah, the main portion of the bumper (the winch mount part) is the same between the 1st gen and 2nd gen, the only difference is the light pods and grille. My driver side pod needs to be hammered out, it got dented a little last winter when I hit that little car, but I can take care of that.
I'll take some pics later tonight and post them up.
Finally found both pod housings and took some pics tonight. I have all the other parts as well, they're just buried in my side of the garage at the moment.
The dent isn't too bad really, I just haven't gotten around to hammering it out yet and then ended up getting the Gen 2 pods anyway.
SolidusJ
FT. Carson, CO
Are they just held in place with self tapping screws?
The pods bolt to the grille, which in turn bolts to the nose of the body. You have to drill four holes total in the body.
This post in my red H3's build thread shows how they go on: http://www.hummer4x4offroad.com/for...-H3-Base-build&p=183260&viewfull=1#post183260
If you look closely at the picture showing just the winch bumper mounted (3rd pic in that post) you can see the holes I drilled on the outer edge of the nose. I then sprayed it with undercoating to prevent rust and hide everything since red shows pretty well behind a black grille. I'll try to pull everything out tonight and take more pictures for you.
rsm688
mississippi
I’ve got a perfect condition Gen 1 bumper I will sell you or trade for a Gen 2. Or if you buy a Gen 2 I’ll just swap pods with you
