Winch primer, please?
Somethingbigandorange
So I read the write-up on Schwarttzy's site about the hidden mount and what size/rating winch will fit. As much wrenching and modding as I have done, though, I don't know much about winches - specifically, how to mount them. Do I need a special bumper? Or just a mounting plate? Which mounts (if necessary) are good, and are the cheap ones usable or tinny POS? Any and all input, opinions, and experience are welcome. TIA.
Enter Hummer
Southwest
No, you dont need a special bumper for a winch (but a ThorParts bumper looks AWESOME). You do need a winch plate that goes between (top or bottom) of the frame behind the D rings. I dont know what is considered "cheap" but I see pleny of good reviews for those $40 plates.
Enter Hummer
Southwest
If you mean a winch plate such as made by CP Photo in MI; like this:
It is more than $40.00 and far from being weak. However, I did reinforce the frame where the D-ring attaches for added strength. But easy to install, but highly recommend two people. (Right NEO?)
Not sure if CP still sells them but here is the link...
http://www.cbphoto.com/highmount/
I took a different route...
the winch plate is welded and bolted to the frame horns.
been this way for years, works excellent - I did cut a hole in the radiator cover to access the controls.
