Life of a hummer?
poweraidon
georgia
Realistically how many miles can you put on a h3 before you need a new engine and all the expensive problems occur?
zackcrum
Corinth MS
I don't think there is an answer to that. It really depends on maintenance, driving style, conditions, mods. But supposedly the engine is supposed to last 400k. I'm at 156 as of today and I think there's someone on here with upwards of 200k
deserth3
Conroe, TX
Design life of the engine is 300K miles.
If you have the misfortune of have the head issue that occurred in 06 and a few 07. That may be shorter.
There is someone here who replaced an engine at 225k. I just replaced my engine at 174k. Though I never felt that my engine ran at it's best after the head was replaced at 25k.
My engine still ran. But had a tick up front, a stumble at idle, and a rear seal was leaking dumping oil on the exhaust. It was also sucking oil up the dirt oil crankcase vent. That was fixed by adding a pcv valve. And yes there is a clean crankcase ventilation vent. Why? I don't know.
So barring something unforeseen your engine should go 300k+.
Sent from my MB886 using Tapatalk
derian06
Red Rockett
Madison, AL
I talked to the guy that actually designed the engine and he said with proper care it could last 450,000miles
I am at 127k right now but thats without the PCM calibrated for 35s so I am really near 136k miles. I probably would never add a V8 but when it blows up I will probably do a 3.7 and add a turbo. They are cheaper then a supercharger and the colorado guys run turbos at 11 lbs of boost reliably and with no internal issues. I would shoot for 7-8 lbs of boost to help the motor last.
As for the trans I plan to build the 4l60e with stronger internals when it goes.
Preventative maintenance and care will make it last a long time. I know that for the 5.3, that some variant of that engine is in basically every gm suv/truck since who knows when. Meaning the kinks have been worked out and it'll run for 500k
Hmm, haven't had any expensive problems in 135,000 miles. Well, except for head (warranty), transmission, exhaust manifold and a bunch of little things like radiators, water pumps, power steering pump, crankshaft seal, thermostat. I'll leave out the non-engine stuff. Not too bad for a truck that only gets driven to the grocery store and back. :wink:
Id also say, that by the time the majority of us roll over 300,000 miles, a new paint job and some sort of frame off restoration will be needed. Simply due to rust(if applicable) and chip, scrapes, and dings from the road.
For me personally, I will reach a point in life where i want to (and can afford it) I will basically do a complete restoration of my H3.But thats just me :thumbs:
Perhaps undercarriage rust protection will help keep rust away longer (preventative maintenance that is) I do this on my truck every 3 years due to the nature of where I wheel which has alot of sea water passes and driving throu mud filled with sea water!
...ah, one of the advantages to living in the desert where it's a "dry" heat and vehicles can live a long, rust-free life.
BTW, have I already mentioned that I love crab legs? :D
chad
florida
i'm at 91,000 miles and the only thing that has happened to my truck is my driver door switch panel switches broke. truck still runs super smooth.
H3Hrly
California
I'v got ~91K on a 2008 Alpha. I had U-joint problem that was under warranty (free to fix but could have cost $3-5K...can't remember). Recently had radiator go bad, and pinging in engine, and disappearing oil :/ ($1.4k to fix). Otherwise, just routine oil changes and service work at dealership. I drive slow and gingerly.
JonBishop
Glendora, CA
Wow 450k!!! Well I'm holding on to it for awhile! I'm at 144k as of right now :) maintenance is on point, fingers crossed for 450k :)
twinmill28
Spilled Milk
450,000 miles? Dude, that's like 897,000 kilometers--if you guys would have bought an H3 out of country, your engine life would be tremendously greater! We need our Canadian friends to chime in here......
And 06H3--turbo? Are you sure about that? I''ve heard they're not desirable for 4x4's off road as they spool up at the wrong time vs. having the power on hand with a SC.
you can get a low spool turbo. Id rather have a supercharger but when I was emailed that just the blower was 5k I figured a turbo can be done wayyy cheaper and easier. It's more for on road then offroad
Woodtick
Ilanoid, UP MI
For all of you talking about rust, try a product called Fluid Film. I just found out about this product this past winter. My under carriage will be getting a good coating this fall.
right, and they're absolutely useless on diesels.... uh, no.
turbos have an envelope of where they develop boost - a smaller turbo develops boost faster, but then is a restriction at higher rpms, a larger turbo is just the opposite. 99% of the time, the turbo is a compromise. With that said, dual scroll and variable vane turbos can alleviate that (as can dual, inline turbos)... but they have some down sides as well because of the complexity and physics. The problem with turbos is always heat and because of that, packaging the intercooler. Ford's ecoboost trucks, put the intercooler right below the bumper... not really the safest spot on a 4x4...
Superchargers can have instant boost (not necessarily true because it depends on the pulley sizes and the efficiency of the blower) and, if it's a roots-style blower it has a water/air intercooler, that is generally easier to package
blowers like Paxton superchargers kind of are the worst of both worlds because they take a huge amount of room.
and with all that said, there are books on the subject and I've left off more than I've added... turbos can work just fine on a H3, though, with that said, turbos with small displacement is kind of the best. In short, you have an I5 H3... turbo... a Alpha, blower for the displacement reason and the packaging reason as there is no room on an H3 Alpha to put a turbo.... ask me how I know, I dare you.
LagunaH1
Idaho
To each their own of course but I'd be worried about if / how an engine with >100 k miles on it would handle the extra power from a turbo / supercharger. If you manage to build the motor to handle the added stress, then the next step will be to build the transmission to handle the extra torque, from there, the question is whether the rest of the driveline can handle the extra forces involved.
Again, to each their own. My priority is reliability.
