BigDogoffroad
- Golden, CO
A buddy sent me this thread. I love finding threads about myself online. I'm new to this forum, but I've been into Hummers for 12 years. I put together a trip to the Moab/Durango area every April and the guys we wheel with are very experienced drivers. The goal for this trip was to "trail test" (read: beat up) the new steering system I had just designed to retrofit the Alpha/HMMWV ECV Sheppard M83 steering gear to the older Hummer frames.
Funny you should ask. The damage was really quite minor despite how the film crew made it look. I scratched my brush guard, bent the roll bar (and damaged those flimsy pieces above the doors that hold the velcro on), deleted the gap in the rear 1/4 panel, broke off one mirror and slightly bent the tire carrier.
I feel bad for the truck, I wonder how much damage it took.... :shame:
Ok bro, I'm sure you would have done better. There were 40-50mph winds and I couldn't see ****.Makes sense, I watched some of the other videos. zero throttle control going up potato salad and even the escalator.
Steering mounting kit including all hardware and outside frame reinforcement plate is only $850. Other parts needed will be the Sheppard M83 steering gear, Alpha/ECV pitman, Alpha/ECV idler, drag link, and steering shaft. You can use your stock PS pump.Steering system will be around 2-3k, and the modifcation that is done, sounds to be drilling and welding certain parts to make it work. When it is actually getting the steering system installed, ill get him to send some pictures. Sounds like since he didn't break any steering components on the trip, that it should hold up very well for us.
Thanks. We were all fine. The film crew have been with us for this event for the last several years and the downhill cameraman who got the best footage loves the risky angles.ouch - looks like that truck was put together really well.
Glad nobody was hurt - has their been a debrief from the owner since this video?
My "spotters" were the guys sitting on the hill eating chips. They have a combined 25+ years of Hummer experience. I hardly ever need a spot but I did holler up and ask them if I was ok, they said I was fine and I proceeded.....proceeded to roll over. I couldn't see and didn't see the 7' deep hole my tire was about to drop into.Without signing up on that forum and reading the whole story.........
3 things: Awesome spotters. That dude obviously has more money than brains. And I bet he drove it home.
See note aboveHe should have had two less on the camera crew, and had some actual spotters.
Not sure what kind of line he was trying to run either.
Ok bro, you try it. The front tire fell 7' vertical before touching the ground.One tap of the skinny pedal would've prevented that.
The reason Hummers go through so many steering parts is complicated. If you have a Rock Ram you will go through a LOT more steering parts because the hydraulic cylinder will destroy your tie rods and once those are loose they will ruin your idler and pitman also.Hmmm, there's got to be a reason the truck is eating up steering parts.
I would be more afraid of cracking the frame with the upgraded steering kit. I mean frames already crack with the stock steering setup I wonder how the frame will hold up to this new setup.
This was my previous truck from our 2012 trip. I have sold that one and built this new one (although they do look similar). It's always good to have your local heavy equipment rental company handy when your wheels falls off. This is downtown Moab directly in front of McStiff's.
Yup, I drove out of the hole I rolled into, then did Jeep Eater, then went for dinner. This was the first day of a 3 day trip. Truck drives fine......much better actually than any other Hummer I have ever wheeled after a hard day on the trail.That actually really sucks, he completely rebuilt that truck only to have it roll on its first run. It looks like he didn't really sustain any major damage but you know H1 guys they are like master mechanics they know how to fix their stuff. I think he also ran another trail after that lol
