I just noticed I forgot to update this thread when I got the rear bumper and the RD Rock Bashers Line-X coated. Here are a few pictures showing the Line-X coating.
I like the Line-X “non-slip” surface on the top of the sliders. It makes a good surface to step on while climbing into the truck. However, if I had it to do over, I'd skip the Line-X and go with a rattle can finish and no-skid tape. The rough surface in the Line-X traps all kinds of dirt which is hard to clean. I might try my pressure washer in the future. Also, I've already torn up the Line-X on the bottom corner of rear bumper (on the trip to the Goodnight Irene claim). I think the rattle can solution would be easier to touch up.
Next, I’ve been pestering CJ to come up with a hold open for the spare tire swing gate. When I’m parked on a side slope with the passenger’s side higher than the driver’s side, the spare gate wants to swing shut and bang against the tailgate. This problem is exacerbated by my 9 degree sloped driveway and my 107 pound spare tire. We discussed many different hold open mechanisms and devices, but they all seamed overly complicated and some had the potential for damage due to operator error. Finally CJ came up with an elegant solution of using a hold open bar like is commonly used on a car hood. CJ went to a junk yard and acquired a hood hold open bar off a 1985 Jeep Cherokee and sent it to me (months ago). I finally got around to installing it, and it works great! I mounted it to the inside of the spare gate arm where it is hidden by the spare gate arm and drilled a “small” hole in the top surface of the bumper. The hold open bar had and a double bend at the tip, which I trimmed off to get a better fit.
Next I added a small hook to hold the bar up out of the way when not in use.
Here are a couple shots from either side showing the hold open in the stowed position and the spare gate latched.
I’m quite pleased with the new hold open. It does its job perfectly holding the spare gate in place even in my 9 degree driveway as shown below.
Thanks a lot CJ for a great solution! Too bad this rear bumper and spare gate isn’t still available to other H3T owners!
