Bebe's Hollywood Half/Tube Doors
jakesz28
Cabool MO
If you could find a body shop or a race chassis shop, with a bead roller. They can roll the panel to give you the look of the h1 doors.
ReconH3
Guardian Angel
Raleigh, NC
That's exactly what I was thinking. Most hot rod shops should have one.
"Ex Umbris Venimus"
Sent from my iPhone
bebe
Moderator
Dayton, NV
Like this one?
My Dad owned a couple of shops (my sister and I own them now) we found this on one of the storage trailers. All I need is the bead roller wheels and we might be able to make this happen.
jakesz28
Cabool MO
Making the rollers wouldn't be that hard. You have the main component. Can't wait to see the finished skin now.
bebe
Moderator
Dayton, NV
Been busy painting for the last day or two:)
Rear Doors
Front doors
Drivers side installed - with mirror
Passenger side with mirror
We are leaving early in the morning for our WeBilt Club Rig inspection for our Disabled Sports Far West Rubicon Adventure....wish me luck :D
It will be my first trip up the hill with no doors. :)
bebe
Moderator
Dayton, NV
Well, I passed inspection....BUT I had a lot of metal sparklies in my rear diff oil. :shame:So Roy (one of our WeBilt members) is coming over tomorrow after work to pull the diff apart and inspect the issue. I think it's the pinion bearing (there has been play in it for a while and the pinion seal has been weeping very slightly). Best case scenario - replace the pinion bearing and reset the gears - worst case, rebuild the whole thing. Either way, it will be a cheap fix.
I need too update my fire extinguisher (out of date....check yours!!) and Rick needs to finally install my bad azz CB radio that he bought me for my Birthday LAST year :giggle:
Then I will be all set for the disabled sports run August 10,11,12th!
These guys go through the rigs with a fine tooth comb....It turned out great!!!
The doors are awesome. I'm so happy. We need to finish the mirrors, speakers, arm rests and skins. I really like driving it without doors. But I need to figure out what to do with my hair - It's too long and blows all over the place. :)
58Bisc
Warminster, PA
Like this one?
Looks like you have the shear dies currently installed on it.
Here is a link to a cheap Habor Freight bead roller. The dies may fit your unit.
http://www.harborfreight.com/18-inch-sheet-metal-fabrication-kit-34104.html
Here are a couple from Eastwood:
http://search.eastwood.com/search?w=Bead+roller
