WTB stock h3 inner tie rod any condition
atvspeed4
massachusetts
I need an h3 inner tierod for mock up. Either 14mm or 16mm. It can be very worn or bent, just need to pull some dimensions off of it without downtime on my H3. They have become almost impossible to find in my area dealerships.
But, GM is supposed to supply parts for 10 years!!! Uh huh.
I had to pickup some hardware at the nut and bolt place so I took one in for a second opinion on the size you wanted.
The lock nut that goes between the inner and outer will also screw on the inner that connects to the rack.
16 x 1.5 but you should check that as well at some point.
I put that in here since it was easiest to find.
In the interest of science if you want some other measurements with scaled pictures post up here or in the thread you started about this instead of the swap meet so maybe search will lead others willing to contribute.
atvspeed4
massachusetts
Thank you for the info. That definitely helps but I will still need to have an inner at the shop to take dimensions of the centering tab that will keep the adapter vertical.
I guess we should continue this in your thread about making a tie rod instead of the swap thread so it can be all together.
There is not a tab on the OEM tie rod.
There are a couple of slots in the end of the rack.
I have a bent inner tie rod. I can ship it to you and you can use the measurements and keep it for however long you want. I know this sounds ridiculous but when your done can I have it back...I have it on my wall of shame in the garage and its my first bent tie rod lol. I will pay shipping both ways also.
AZtraveler
I have a pair of 14mm inner & outers that I used to carry as trail spares for my 2007 H3. They are like new and I'd be willing to sell. If anyone is interested just shoot me a PM.
atvspeed4
massachusetts
haha I used to have a wall of shame for bike parts when I used to downhill mountain bike. We can pay for shipping both ways not a problem. Send me a PM with your paypal info and what you need for shipping and we can send some $$ your way. Thank you!
I sure thought I put in that post about the nut screwing on both ends that it was on a 16mm tie rod but it's not there. I would venture a guess it will not if it is off a 14mm. Weird must be in the cloud?
I have never broken a tie rod by some stroke of luck but did break a rack after some hard wheeling over time I think it loosened the pass side bushing and then a final blow when my locker was not working and I got a bit heavy on the skinny pedal, ok a lot, I was po'ed at the dealer after 3 attempts.
Anyway I have collected images that people posted and some claimed of a hall of shame of tie rods. I posted some of them in the past buried somewhere but this might give you an idea of the point of failure.
Anybody want to add some?
http://www.hummer4x4offroad.com/forum/showthread.php?1948-Tie-rods-broken&p=36246#post36246
